Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
![]() ![]() ![]() ![]() Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Best 3 modifications to rear, to gain traction?
It's time to work on the rear. Which are the most helpful modifications for straight-line traction? I'm currently looking at:
BMR Rear craddle bushings, Pro. Poly BMR Rear toe rods. Poly (do I need adjustable?) I'm not lowered.. BMR Rear Trailing Arms Poly BMR Rear trailing arm bushings poly BMR Extreme Anti-Roll bar I had solid rear bushings in my Fox-Body and don't want that for this car. Going with poly to hopefully keep it street-able. If you couldn't afford them all at once, which would you buy first?
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Tuning Triples and FF, FIC1300, Mcleod RXT 1200HD, 1030whp 925wtq.
Go solid on the cradle bushings I daily mine and don't even realize their there, car accelerates much better with no wind up of the cradle and is more planted.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Suede Steering wheel, short throw shifter. Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 GS Calipers, PAFDT Solid Cradle bushing, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. |
![]() Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
I run the BMR poly bushings and I like them. Lots of guys are running the solid bushings with good reviews. Either one will be an improvement.
If you do the toe rods at the same time you do cradle bushings you will save yourself a small amount of work. The cradle has to be lowered a little bit to get to the inboard mounting bolt out of the driver side toe rod. It's really not a big deal, but I thought I would throw that out there.
CAI Cold Air Intake; Comp Cams LSR Series; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; AEM Wideband; N2MB WOT Box;
Tuned by Throttle Works 467whp 419 wtq McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
I have all bmr on my car. Cradle, trailing arms, toe rods, upper rear control arm poly bushings, all other bushings are poly as you listed. I am lowered on Ridetechs 1” and don’t need adjustable arms. I don’t drag race but I have no wheel hop in off the line starts in autocross or on street. More of traction limited now and how much I can rev on launch without spinning or laying rubber down before hooking up.
And the ride wasn’t hurt at all or very little, a little more solid over bumps. You will get some of that feel if you go to stiff on the rear swaybar |
GPI Sales Consultant
#1 thing is cradle bushings - dramatic difference.
2011 2SS SGM - CAI, PTB, Rod-Mod and ported intake, GPI SS3 cam, AR LTs 1.875", X-pipe, high flow cats, cutouts. 25% UPD, 169*F stat, Ideal Garage clutch master and reservoir, Tilton 6100 HRB, Mcleod RXT, Yukon 4.11 gears, TruTrac Differential, LPW Diff Cover, BMR Pro diff bushings, Pegasus Solid rear sub-frame bushings. 497rwhp. 11.67@119 2+ton raceweight.
Got a question about a GPI product? Feel free to shoot me a message! |
#6 |
Thank you guys. I'm def gonna start with the cradle bushings. I'm gonna hold off on toe rods and trailing arms, until I can swing the adjustable ones. The tubular style looks way more rigid and its always a good idea to have adjustability.
As far as that drivers side toe rod bolt, I heard you could remove the trailing arm (or was it control arm?) from the spindle side, to create enough movement to get the toe rod bolt out.
#7 |
Finally got the cradle bushings installed. What a bitch. I didn't realize how massive these bushings were until I held them. I beveled the edge of the pin to help it slide into the bushing. Tight fit.
The cradle bushings alone made a huge difference! Under power, the rear was twisting causing the car to steer itself towards the curb. Now with the new bmr bushings, it just goes straight. Still spins some, but it goes straight. Money well spent. Moving onto toe rods and trailing arms. Trying to decide if I should spend the extra cash on the adjustable arms/rods or not. I've never been to the drag strip, so I doubt I will need the ability to adjust the toe... Anyone see a reason I need the adjustable stuff?
#8 |
For me, I'm ok with the toe-rod being fixed. It's still adjustable for general alignment purposes, just not quick adjust for on/off track tweaking. I am curious to see what you experience with the toe rod and trailing arm changes, having done the cradle first. I'm on the fence for a next mod, and I'm considering toe/trailing arm. I really want to get as much slop out of the driveline as possible, I'm just not entirely sure it's there. I'm suspicious of my trans mount, I believe the 10-11 is a softer part than 12+. Might be upgrade time.
#9 | |
![]() ![]() ![]() ![]() Drives: 2010 SS L99 Join Date: Sep 2018
I will add, for adjustability purposes, I am not lowered but with my camber bolts I can get my rear camber to 0, for my drag alignment just fine
11.079 @ 122.99mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
#10 |
I'm running adjustables on my but I do track my car and the alignment shop really likes them for the ease and amount of adjustment they provide.
Orange Krush II
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
What about diff. bushings to stabilize the punkin? (And yes, I meant to say punkin)
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413, BMR Cradle/Diff/front Radius rod/lower control arm bushings/1" lowering springs, DSE 32mm fe4 rear sway bar. GM fe4 shocks/struts/LCA's, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20.
Avenging Orange: 42 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 KICKING CANCERS ASS SINCE 2015!! |
#12 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
big difference going to solid cradle bushings. car plants it better. I didnt notice any introduced NVH other than when i go over a bump, i can feel it more
Bone Stock |
#13 |
![]() ![]() ![]() Drives: 2015 Camaro Join Date: Aug 2018
I installed the Hotchkis 32mm rear sway bar on mine on the stiffest setting. Felt like I took out 300 lbs from the backend/trunk and the car accelerates much better out of the hole. Best mod I did to date.
2015 Camaro Summit White
#14 |
Instagram: Sangstah
Drives: 2014 Camaro 1SS RS SIM Join Date: Sep 2016
^yup sway bars make a huge difference, running Pedders 27mm front and 32mm rears and the car is planted.
2014 SS - BTR Stg 2 Cammed L99 1SS/RS FBO - "AleSSandra"
Thread Tools | |
