09-25-2018, 02:11 PM | #1 |
Drives: 2021 Camaro 2SS Join Date: Sep 2018
GM working on a solution for the A8 Shudder????
My service adviser stated that GM is trying to come up with a remedy for those who have gone thru the flushes but have not had their TC changed. She stated that the transmission shop is backed up to December. She also said to try and hang on until it's unbearable. Kind of a sucky answer but she said I'm sorry. I had mine flushed around 6,000 miles and now it's back at the 13,500 miles mark. So anyone heard any thing about a fix that hasn't been discussed here on the forum??
09-26-2018, 09:38 AM | #2 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Probably another damn band aid they are coming up with...I doubt there will be any serious fix for these issues in the 6th gen.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered) 3800 Status - 10/13/15 (Built) 6000 Status - 12/22/15 (Delivered) |
09-26-2018, 10:37 AM | #3 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Change the Converter and have the TCM tuned to get rid of the slip tables. If not willing to tune, then trade the car. SO far the fluid flush is a band-aid and replacing the converter with a OEM "updated" unit is hit or miss.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
09-26-2018, 03:01 PM | #4 |
Drives: 2016 Camaro SS Join Date: Sep 2018
I think this is what I am going to do, buy one from Circle D and have the trans tuned.
09-26-2018, 03:48 PM | #5 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
My service advisor reached out to me, without asking for it, that a new converter and negative/ground cable kit were on order for my car. I also got the same line about the transmission queue being backed up in the shop and I would have to schedule it further out once the parts arrived. But nothing was said about GM TAC continuing to actively work the TSB's for the 8L90. Maybe we'll get the 2019 MQE "improvements" (calibration and torque converter).
At this point I'm wondering what the prolonged exposure to the problem has done to the clutches, bands and valve body. I know it is crazy for GM to swap all new transmissions. But if GM wants the issue behind them, they should look at a rebuild kit to replace clutches, bands, test valve body (replace only if fails), swap torque converter and then update calibration before sticking it in fast adapt learning. May want to check the rear diff while they are at it as well, since fluid contamination would affect it as well. |
09-26-2018, 04:12 PM | #6 |
Wow, Thanks JaxChris. that's great information.
09-26-2018, 09:00 PM | #7 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
I was under the impression that there was a liquid-to-liquid heat exchanger for the differential cooling. So the “cool” transmission fluid cools the differential, but the fluid is separate (just like the coolant-to-oil cooler for our engines). No way for there to be contamination. Hopefully someone will jump in if I’m wrong.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
09-27-2018, 01:48 PM | #8 | |
09-27-2018, 05:07 PM | #9 |
09-28-2018, 02:04 AM | #10 |
Drives: 2020 Camaro 1SS Join Date: Mar 2018
Maybe Chevy should instead consider retrofitting A10s into A8 cars that can't be straightened out. Piece of cake mechanically so it should just be an issue of making the 10 speed tranny software work. Even if they wouldn't do it as a warranty replacement they could make it a reasonable cost upgrade for problematic A8 cars.
09-28-2018, 07:32 AM | #11 |
I have been driving my car around in Sport mode and honestly I don't even notice it doing it anymore. I don't know if it is coincidence or not but I noticed it doing it badly in Touring mode and not at all in Sport.
09-28-2018, 08:21 AM | #12 | |
I do agree with you that GM needs to recall this issue because tuning voids warranty and that is really the only way the issue will be fixed as long as the converter and trans are in good working order. The problem is that a recall would likely cost them millions since several platforms have a A8 transmission. So they will continue to band-aid the situation until warranties are up and write the issue off. The A10 sounds like a good solution but I still have a few concerns. 1 it's not the same A10 as the ZL1. It's a 10l80 which is rated in Newton power less then the 8l90. 2 how is GM handling the TCM tuning on this A10 since AFM will still be present? Will it have the same slip tables in the TCC and end up with potentially the same issue? Had GM done away with AFM on the 19 SS with A10 I would feel a little more confident that it will be a better deal then the A8. I can say I am not hopping on the A10 bandwagon until it proves itself to be worthy.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 09-28-2018 at 09:41 AM. |
09-29-2018, 06:07 AM | #13 | |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
I had the trans flushed with the new fluid at 1500 miles and tuned at 2000 miles, it was and is still 100% perfect with absolutely no issues. Will see how it fares, hopefully the torque converter had not been damaged yet. (As to drivetrain warranty, my supercharger came with one and it covers the transmission as well, so while it is a limited warranty in terms of max dollar amount, at least I'm not fully out in the open.)
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
09-29-2018, 02:40 PM | #14 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
GM flushed the tranny and changed the filter, its perfect now and it was shuddering like crazy. My Camaro used to do that but its been down the drag strip over 180 times so I don't know if it even does it anymore.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
