#Camaro6
BeckyD @ James Martin Chevy
Old 03-12-2024, 10:46 AM   #1
Bird71
Drives: '23 Camaro ZL1 A10 / '23 Blazer RS
TCM Tune Only
Hello all,
How much of a gain can be had with only a T93 tune on a nearly stock '23 ZL1 A10 (with ported TB and Green Filter)? Just curious on what a difference it could actually make.
2023 Camaro ZL1 A10
Riverside Blue Coupe
1/16/23 - 1100
4/20/23 - 2000
5/08/23 - 3000 (TPW-5/22)
5/12/23 - 3400
6/01/23 - 4150
6/05/23 - 5000
6/07/23 - 6000
Bird71 is offline   Reply With Quote
Old 03-12-2024, 11:30 AM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Bird71 View Post
Hello all,
A decent TCM tune is generally worth .2-.3 seconds in the quarter mile from faster shifts and reduced torque management.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
Old 03-12-2024, 12:04 PM   #3
Bird71
Thanks Josh. In your opinion, does a tuned TCM cause any more wear and tear than the factory tune which pretty much strives for max fuel economy?
2023 Camaro ZL1 A10
1/16/23 - 1100
4/20/23 - 2000
5/12/23 - 3400
6/01/23 - 4150
6/05/23 - 5000
6/07/23 - 6000
Old 03-12-2024, 12:22 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The OEM TM is also there to protect parts of the driveline.
'20 ZL1 Black "Fury"
Old 03-12-2024, 03:48 PM   #5
Joshinator99
Under normal operating conditions, no. It might even extend life due to less slippage.
BUT, Radz28 is 100% right. When you’re under full power, that torque management helps protect the OEM components. While I suspect you’d be fine at your power level, anytime things get juiced up a bit there’s always a risk to breaking stuff…! It’s part-and-parcel of modding a car unfortunately.
If you’re worried about your warranty do not mod the car. If you want a fast car then spend the money and let the chips fall where they may.
Old 03-12-2024, 04:25 PM   #6
SpeZ
Drives: 2019 ZL1,2016 2SS, 2017 320d F30
I wouldn't tune the TCM even at stock power.
The trans is pretty expensive and you don't want any issues. Warranty will be void.
Unlocking costs like 250$, licensing costs I believe another 200$ and then the tune itself costs also.
unlocking requires them to open up the TCM and change some stuff.
At the end its alot of money for high risk and results in a unoticable faster shifting.
Like some said at 1/4 you save maybe 0.2 seconds.
I got mine at 830 HP and didn't let my trans tune.
Shifts would occur with higher torque and wears down the shift plates in the trans. At normal driving not a big deal, but at WOT...
excuse my english
SpeZ is offline   Reply With Quote
Old 03-12-2024, 04:57 PM   #7
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The 10l90 is robust enough you can command full torque shifts at stock power and not phase it. The TM is in place to make the car shift like a European sports car and help keep the driver on the road. Cold pavement, cold tires, full torque shift = tires breaking loose.
When I tune them, I drastically reduce TM but I still allow for some timing pull on shifts.
I change the tune mainly for a better driving experience. But the stock tune isn't bad on the A10 stuff.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 03-12-2024, 06:25 PM   #8
Joshinator99
FYI warranty is void with any mod that actually makes a difference. And the difference in shift times when tuned is definitely noticeable…
Old 03-12-2024, 06:26 PM   #9
Joshinator99
Mandatory plug for King’s TCM tuning…
Old 03-13-2024, 10:34 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
+2. He knows what he's talking about.
BUT - do what you're comfortable with. It's your $$$.
Old 03-13-2024, 11:31 AM   #11
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
I disagree. Also, without a trans tune you're either fudging the airmass/torque numbers or your car is slower than is should be due to torque management in the TCM. Either way there are plenty of good reasons to tune the TCM, especially if you're not stock. But even stock you can improve performance with little to no negative impact on the 10L90.
I agree, the stock TCM tunes even on stock cars is a bit sloppy to my liking. Some people are OK with it but I find that many want the car to feel more sporty vs soft even at part throttle.
GM Gen V Calibrator
Megahurtz is offline   Reply With Quote
