07-05-2016, 10:50 AM | #1 |
Drives: 2017 2SS Join Date: Apr 2016
10 speed transmission (for new ZL1) - technical article
Here is a really nicely detailed technical article on the 10-speed transmission.
Wheels: GM gives insider look at Camaro 10-speed automatic transmission The all-new Chevrolet Camaro ZL1 10-speed automatic transmission is the first 10-speed automatic for a volume production car. [All images courtesy: General Motors Co.] Engineers who developed the new 10-speed automatic transmission available in the 2017 Chevrolet Camaro ZL1 built on the experience of previous, critically acclaimed Hydra-Matic multispeed transmissions to push its performance, refinement, and efficiency advantages to a new threshold. The 10-speed is an all-new design -- and the first-ever application in a car -- with a wider, 7.39 overall gear ratio spread that enables the ZL1's supercharged engine to remain at optimal engine speeds during upshifts. "With world-class shift times on par with the world's best dual-clutch transmissions and the refinement that comes only from a true automatic, the 10-speed delivers incomparable performance on and off the track," said Dan Nicholson, vice-president, GM Global Propulsion Systems. "It also leverages the experience of our other multispeed transmissions to deliver that performance with greater efficiency as its use expands into other vehicles." The driver-focused interior of the Camaro ZL1 features standard Recaro front seats, along with a sueded flat-bottom steering wheel and shift knob. Chevrolet's Performance Data Recorder is available and allows drivers to record, share, and analyze driving experiences on and off the track. The wider overall ratio enables a lower numerical top gear ratio -- an attribute that reduces engine speed on the highway, which contributes to greater fuel efficiency than a comparable eight-speed transmission. Improvements in spin loss complement the optimized gearing, further enhancing efficiency. And while the Camaro ZL1 will be the first GM vehicle to offer the new 10-speed automatic, designed for rear-wheel-drive applications, it will be available in eight additional vehicles by 2018. Additional transmission highlights:
The electrohydraulic valve body assembly contributes to quick shift times.
The front support assembly with its clutch spinloss reduction features, among other things, contributes to the overall efficiency and compact size of the new 10-speed automatic transmission.
A look at architectural features and packaging Thousands of hours of CAD analyses were made during the development of the Hydra-Matic 10-speed transmission, driving a comparatively compact design envelope comparable to the eight-speed automatic. A one-piece aluminum case with an integral bell housing helps reduce weight and enhance powertrain stiffness, while a unique 260-mm integral turbine clutch torque converter design reduces complexity and helps make the converter thinner, which contributes to the transmission's packaging. The 10-speed has four simple gearsets and six clutches: two brake clutches and four rotating clutches. That's only one more clutch than the eight-speed, despite having two more forward gears, contributing further to the compact packaging, while also improving spin losses to enhance fuel efficiency. The durable input ring gear and overdrive sun gear assembly. A unique triple-clutch assembly in the middle of the 10-speed's architecture is a primary enabler for packaging 10-speed content in the same space as GM's six- and eight-speed transmissions. The triple clutch assembly design. The 10-speed also features a variable-displacement vane pump, which optimizes transmission fluid pressure, based on speed and load, to enhance efficiency. The variable displacement vane pump helps improve the overall efficiency. The output ring gear and reaction carrier shell design contribute to the transmission's compact size. 7.39 ratio spread and faster upshifts The new 10-speed's greater overall performance and efficiency are due primarily to its wider 7.39 overall gear ratio spread, which enhances off-the-line performance with a more aggressive first-gear ratio than GM's eight-speed automatic. Smaller steps between the gears also help the engine maintain the optimal speed for maximum power at almost all speeds, especially when exiting a corner on a track. Adaptive shift controls such as Performance Algorithm Shifting and Driver Shift Control enhance performance driving. Performance Algorithm Shifting (PAS) monitors how assertively the driver is using engine output to determine at what engine speed to upshift or downshift. Driver Shift Control allows the driver to shift the transmission via the steering wheel-mounted paddle shifters. Electronic safeguards prevent over-revving if the wrong gear position is selected, but they rely on the driver to make upshifts or downshifts. Gear changes are mainly executed with clutch-to-clutch action, where an "on-coming" clutch is engaged and an "off-going" clutch is released in a precise manner to achieve the ratio change. Certain key shifts, however, are made with a freewheeling action, such as 3-1 downshifts, where a plate clutch is actively disengaged while a mechanical freewheeler clutch automatically engages with optimum synchronization. The torque converter is 260 mm in diameter and features a lock-up clutch. It also uses electronic-controlled capacity clutch (ECCC) technology, which employs a small, regulated amount of slip to dampen out engine pulses for a smoother running drivetrain, especially during shifting. Reduced spin losses and new transmission fluid Friction-reducing design features, including all-new ultra-low viscosity transmission fluid, internal thermal bypass, minimal number of non-applied clutches, and other lower mechanical spin losses, contribute to the 10-speed's effect on improved vehicle efficiency. The low-viscosity fluid helps reduce friction across the full temperature operating range, which enhances fuel efficiency. Additionally, the internal thermal bypass allows the transmission to warm up faster to its optimal operating temperature, further contributing to fuel efficiency. GM control system The shift-time quickness and responsiveness are accomplished by leveraging the base transmission hardware in concert with GM exclusively developed algorithms, software, and calibrations. An externally mounted electronic control module executes millions of controls instructions every second. Source: General Motors Co. Published June 2016 |
07-05-2016, 11:04 AM | #2 |
Drives: BMW M3 Join Date: Jun 2016
Sweet article and video
INSTAGRAM: jellismotors |
07-05-2016, 01:49 PM | #3 |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
Very nice article.
07-05-2016, 02:02 PM | #4 |
Drives: truck Join Date: Aug 2015
Nice find!
07-05-2016, 02:59 PM | #5 |
Bump in the night
Drives: '84 Monte Carlo SS, '15 Optima Join Date: Oct 2015
Tagged, atta boy, good find!
07-05-2016, 03:04 PM | #6 |
Drives: 2017 ZL1 10 Speed Hyper Blue Join Date: Jul 2016
Very nice find !!
2017 ZL1
07-05-2016, 03:06 PM | #7 |
Drives: Car Join Date: Jun 2010
"as well as other design features, the 10-speed automatic has lower friction that contributes to greater fuel efficiency over GM's six- and eight-speed automatics. "
Which will hopefully mean no GGT on ZL1 |
07-05-2016, 05:44 PM | #8 |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
I think some people are severely overestimating this new transmission. The biggest difference is an addition of a new gear between 4th and 5th, where the old 5th becomes 6th, and an addition of an OD gear before 8th. 10th gear is essentially the same as 8th on the 8 spd. Even with the new snake oil in the transmission, I don't see an improvement of more than 1mpg highway. City might see 1-2mpg. That may get it out of GG tax, not sure.
As for performance, it toots it's own upshifting horn, which I thought the 8 spd did fine, but not much is mentioned or cited with raw numbers of it's downshifting or input response time like they do for the upshifts.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
07-05-2016, 08:03 PM | #9 | |
Drives: 2016 Chevy Colorado Z71 Join Date: May 2015
2016 Chevy Colorado Z71, 2011 Roush Stage 2 (Sold), 15 Mustang GT PP (Sold), Red 18 Camaro ZL1 to come.
07-05-2016, 08:26 PM | #10 |
I hope it's a performer too, that would be great. Finally let the automatic reign supreme once and for all over it's manually shifted brethren.
07-08-2016, 01:55 PM | #11 |
Track performance king might just be the ten speed...extra coolers should be standard to kept temperatures under control.
It lol be interesting which transmission was used for "ring" lap time
2008 Blk C6 Z51 NPP M6/2008 Silver CTS AWD FE2 304hp
07-11-2016, 09:30 AM | #12 |
Drives: 2017 Ford F250, 2019 Lincoln Navi Join Date: Apr 2016
Great read! Thanks
Instagram: MattZ_L1 Vengeance Racing Built
07-11-2016, 05:53 PM | #13 |
Drives: 98 camaro turbo Join Date: Nov 2009
If youre worried about downshifts and how quick it shift after you click the paddle then get the manual and make it shift as quick as you are.
On topic: much like the ltx platform: i love how GM has stayed with improving on older technology and not reinventing it all together. Why 4 cams when you can do it with just one... and in this case why a dct with terrible traffic manors when you can do it with a shinner slushbox.
07-11-2016, 11:21 PM | #14 | |
On the flip side, how come they got rid of their OHV V6's? Why don't they just lop off two cylinders and create a V6 based on the LT1? And the longer both companies go without developing a proper CVT, the worse off they'll be in the long run IMO.
