06-23-2016, 02:06 PM | #1 |
Drives: 2016 Camaro RS Join Date: Jun 2016
Why did my 2016 Camaro RS shut off after idling for some time?
I started the car using the push/start button and turned on the AC and left it that way for about more than 20 minutes under the heat of the sun. Then I just suddelnly heard from the inside of the house that the car shut off and so I turned it back on after several minutes and fortunately it started with no warning lights activated and then I just drove off. Was that because of the car's computer trying to protect the engine? Or was the oil pressure to low? I'm really worried about it because it is brand new.
06-23-2016, 02:18 PM | #2 |
Drives: SS,PaceCar,ZL1,1LE,C7Z51,Z06,17-ZL1 Join Date: Jun 2009
...It operated correctly...
If it was started with remote start... The engine will continue to run for 10 minutes. After 30 seconds, repeat the steps for a 10-minute time extension. Remote start can be extended only once. ...from Owners manual page 33.. Becky |
06-23-2016, 02:21 PM | #3 | |
06-23-2016, 02:23 PM | #4 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
That is a great feature!
My friend was from Alaska and had an early remote start on a 91 grand am. More than once he sat on his keys in his pocket, hit the button and his car started and didn't shut off till it ran out of gas. In our apartment complex his car was too far away for him to hear it start. Whiskey |
06-23-2016, 02:27 PM | #5 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
If started from the dash, it should not be shutting off, unless we have another undocumented "feature" GM has given us......
06-23-2016, 02:27 PM | #6 | |
06-23-2016, 02:28 PM | #7 |
06-23-2016, 02:30 PM | #8 |
I wonder if it has anything to do with not having a key? Is there a limit to how long the car will run without a key?
Whiskey |
06-23-2016, 02:33 PM | #9 |
06-23-2016, 02:58 PM | #10 |
Drives: Gen 6 Camaro RS Join Date: Dec 2015
Maybe this happened with your keys attached to your pants?
06-23-2016, 03:14 PM | #11 |
Drives: 16 Camaro SS Join Date: Jul 2012
Like the OP said, he did start the car from the inside with the push button, therefor, he can not cancel a remote start' as it was not started remotely.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
06-23-2016, 03:17 PM | #12 |
Maybe OP need to check the engine oil level?
06-23-2016, 03:18 PM | #13 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Maybe it has a limit on how long it will run when it doesn't detect the transponder in the "key"?
Life after retirement |
06-23-2016, 03:18 PM | #14 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
I realize that this is somewhat off topic, but why on earth would anyone want to let their car sit idling for 20 minutes? I am not sure how well our engine management systems do at idle, but it can't be good for the car.
This is that witty and clever statement that makes you chuckle.
Tags |
computer, engine, idling, issue, shut off |
