04-01-2019, 03:35 PM | #1 |
Diff and Axle question
For anyone here who has the 3.91 gears
What and how much power can that diff hold? and how much power can the stock axles hold ? and would it be better to just change the axles before the diff ? Sorry for the 21 questions I want to make sure I get as much info as possible before I pull the trigger and get everything done.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
04-01-2019, 03:50 PM | #2 |
Drives: 2013 Camaro SS Join Date: Apr 2017
Thats a hard question to answer. People have broken their stock axles and diffs on stock power and some have held up over 700hp. Some have been into the 9's with stock rear, axles and suspension, some shatter running 13 second 1/4 runs. A lot has to depend on wheel hop, tires you are running, how hard you are launching, M6 vs Auto. There is so much to that question that sounds simple. My stock rear and axles have handled my 512 rwhp just fine with track runs and beating on the street. I have yet to run drag radials though.
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
04-01-2019, 04:41 PM | #3 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I agree with above.
Yea, a lot of variables at play. The 1LE diff housing is the same as the SS, just has different gears. Wheel hop can destroy diffs and axles.
More to come. |
04-02-2019, 12:08 AM | #4 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
This is like building an engine a lot of things have to work together. If you address a variable then it will only move the weak point elsewhere. A simple gear change may help but it’s possible you may have other issues. I did the gears, tires, axles, diff, and full BMR. It’s just the price of business.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
04-02-2019, 07:52 AM | #5 |
GPI Sales Consultant
These guys are on point, there are guys cutting 1.5 or faster 60' times season after season on sticky tires, good prep, and stock axles and rears. There are also guys that can take a freshly built rear end and thrash it their first time out - it's really about how you use it. Being setup well goes a long way, and I believe the LPW cover is also worth the money for the added strength and stability. But usage will usually dictate the life of the drive line. Drive line shock (clutch dumps, wheelhop) will kill things in a BIG hurry - and sticky tires will amplify the ill effects of those things. I believe a little drive line preload on any hard launch goes a LONG ways to keeping things alive.
My personal preference is to have a well built SS diff (quality gears, TruTrac posi, LPW support cover) with stock axles. Stock axles are pretty decent in what they will tolerate, but will fail eventually under hard enough use. I like to think of the axle as a fuse for the drive line - I'd rather pop one of those once and a while than continue to rebuild rear ends (done that too many times).
Got a question about a GPI product? Feel free to shoot me a message! |
04-02-2019, 11:04 AM | #6 |
I am going to get the car boosted (eventually)
I know down the line I would need to change the driveshaft, and axles. I didn't know if the 3.91 gears can hold a boosted application. That was my question
Specs
04-02-2019, 12:29 PM | #7 |
SomeguyK
You should have stated that question initially. Most will tell you 3.91 are too much gear for boost, and to stick with 3.45. Any gear will "hold" the boost...but just like everything else....they can break.
More to come. |
04-02-2019, 12:31 PM | #8 |
It's definitely still a "it depends" type of situation. The longer 1st 2nd 3rd of a MM6 trans in a 1LE will help tame a forced induction application to some extent - but eventually a change to a 3.73 or even 3.45 ratio might benefit the car, depending on the type and amount of boost, and how you're going to use it. If you plan on drag racing the car I would imagine once boosted you're going to need to upgrade everything from the crankshaft back, except for the transmission itself.
04-03-2019, 08:32 AM | #9 | |
Specs
04-03-2019, 11:10 AM | #10 | |
