Old 07-14-2015, 10:37 AM   #1
Sharp406
Drives: 2010 SS/RS 6 Speed
Lsx 427
Have a couple of questions, Have a friend wanting to sale a LSX 427 short block with Lunati Crank, rods, and pistons..for 5 grand, short block has 5,000 miles on it assembly has 0 miles. Stock heads and pan should bolt right up right? Also throwing in Arp bolts and T18 melling hv oil pump. Questions are good deal? What else would i need besides better heads and a tune?
Sharp406 is offline   Reply With Quote
Old 07-14-2015, 10:39 AM   #2
Bizaro
Drives: 2015 Redhot 1LE
Good deal buy it
Bizaro is offline   Reply With Quote
Old 07-14-2015, 11:54 AM   #3
Unreal
Drives: 2006 Z06
Assuming all is good, that is a good deal.
Different cam, and I wouldn't put stock ls3 heads on a 4.125 bore setup. It can work, but I would get some aftermarket heads ASAP, and a cam spec'd for a 427.
Pan bolts right on. Oil pump should go right on assuming it has the correct short crank. Make sure the crank is correct for your application. Same reluctor and snout length or that is a real pain to fix.
Nick
Corvette Z06 -1200ish rwhp
Old 07-14-2015, 08:22 PM   #4
USAFS197
USAFS197's Avatar
Drives: 2019 Corvette Z06
Even stock LS7 heads would be better, no?
2019 Corvette Z06 3LZ 630whp, 701wtq: Halltech CAI, Corsa Double X-Pipe, AWE Touring Axle Back, LMP LT4 Lid, Pray 93 tune. DSC Sport V4 Controller (street/track alignment), fully lowered on stock bolts, BC Forged EH172's w/ Toyo R888R's.
USAFS197 is offline   Reply With Quote
Old 07-14-2015, 08:28 PM   #5
Unreal
Drives: 2006 Z06
For power, yes, for reliability, no.
Nick
Old 07-14-2015, 09:20 PM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
The price is nice if you want to go heavy with a LSX iron block the question is why 5000 miles on the block and not with those parts.... ? just the bare block is like 2200 and can be made into a 500 cube stroker, so maybe someone went Dart block instead and pulled the internals? I bought a 428 stroker from Jerry at SAG performance he is on Ebay selling strokers you should maybe talk to him. I went new g.m. aluminum block as I am a daily driver and the internals I can always use later for a new block if I ever wear the new one out. Our blocks as you know are 1200$ throw away as they can only be honed .020 over and that's if the cast in sleeves are straight.... I thought about going cast iron and could have done it cheaper actually, yet quality is in various upper price range iron blocks, and they can be sleeved later and bored etc for a longer life yet weigh more but are after all stronger.
Just as with my old hot rods though marrying iron and aluminum means re-torque of the head bolts periodically as things expand differently and aluminum intakes would pit eventually also married up to iron mainly probably from the radiator fluid acidity.
On my ls3 stroker I had to get a mast Windage tray, and do not know about the LSX for compatability to ls3 parts, you should talk to a machine shop that knows. Just look UP LSX stroker 427 on ebay and you will find custom engine supply Jerry in Angola Indiana, he was a nice guy just a busy machinist.
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr, Powermaster xs 9509 starter, BMR strut brace,trailing arms, toes, bushings, Crossfire wheels & extreme contacts, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 07-16-2015, 11:25 AM   #7
Sharp406
Well now he said he would take 3grand for it plus my short block, (has 36,000 miles on it) so debating I would still need heads, timing chain, cam and a tune that's all I can think? I'm still on the fence about it would be first time short block swap.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
