04-16-2018, 04:12 PM | #1 |
|Engineer|
Drives: 2016 Camaro SS Join Date: Aug 2016
LT4 fuel upgrades install time?
I am getting the LT4 HPFP, injectors and ZL1 fuel pump assy. installed along side my Magnsuon blower - anyone know what the general install time for the fuel upgrades portion would be?
04-16-2018, 05:58 PM | #2 |
Drives: SS 6 speed of course Join Date: Jan 2016
With the intake off, the HPF system: including injectors, would take say 40 minutes to R and R at a normal place, I 'm sure some will claim 20 minutes, but we are not talking about racing, heck somebody with all the tools lined up and parts our to the bag probably put that under 10 minutes... till a clip breaks off one of the injectors... The LP side... well gotta drop the tank and to do that.... will it gets interesting.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
04-17-2018, 09:13 AM | #3 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
I'll be doing the full system soon but I plan on an auxiliary low side pump rather than dropping the tank. More money, less headache.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
04-17-2018, 10:05 AM | #4 |
My thoughts too, plus they seem to supply more vs the LT4 LPs intank.
04-18-2018, 09:53 PM | #5 |
Drives: 2016 Camaro 1SS Join Date: Feb 2018
Who has best pricing on LT4 injectors and Pump?
Ray |
04-18-2018, 10:12 PM | #6 |
|Engineer|
Added time to deal with one of the fuel lines. The one shipped with my flex fuel sensor is not long enough, the one shipped with my Mangsuon is mostly long enough, but crimps near the left side adapter. My shop is going to fabricate me a new one since the ones I was given don't quite fit.
It doesn't look so bad in the photo, but when held exactly how it needed to be.. |
04-19-2018, 08:49 PM | #7 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
So where is the HPFP located at, under the intake?
I am tempted to put the LT4 injectors and HPFP in my 1LE before I drop it off for the Procharger install. |
04-19-2018, 09:46 PM | #8 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Sorry, I am dumb on this one. What are the options for a "low side pump" instead of the in-tank pump. I didn't realize there was another option.
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
04-20-2018, 10:22 AM | #9 |
Drives: 2016 Camaro 2SS Join Date: Sep 2016
DSX makes an auxiliary pump that to my knowledge pushes more fuel than the LT4 in tank pump. The only caveat is you have to drill into the gas tank. Kind of scary at first but the whole system takes less than 2 hours to install. Whereas the in tank is like 6-8 hours I believe.
04-20-2018, 03:02 PM | #10 | |
I'm looking at the DSX kit which is $1000 and the Skid Mark Garage kit which is $600. Skid Mark says they use the same Walbro pump that DSX uses. I have the DSX E85 kit so I would like to use their kit but $400 difference is significant.
04-20-2018, 03:29 PM | #11 |
Twin Turbo
Drives: 2016 2SS Join Date: Jul 2016
Removing the Exhaust and Driveshaft is probably the most difficult part of dropping the tank.
If your going to drop it make sure you have the fuel level below 1/4 tank & have the lock ring tool to properly install the lock ring.
Boost, Boost & More Boost
Instagram = BoostedSS |
04-20-2018, 04:54 PM | #12 | |
Drives: 2015 Camaro 2SS 1LE Join Date: Apr 2015
2015 2SS - Base A6 - Sold/Brother/Traded
2016 Camaro 2SS - A8 | MRC | NPP | 725rwhp - RIP 2015 2SS 1LE - RS/Sunroof Mods: Headers, Borla ATAK, intake - Sold 2018 M2 Exec - Current |
