02-25-2020, 09:12 PM | #1 |
Drives: 2001 corvette Z06. 2018 ZL1 Join Date: Jan 2018
Gas problem. No 93 octane
The highest octane available in western Colorado is 91. I’m at 4500 feet elevation. Looking for a safe solution to maximize the performance in the Z.
02-25-2020, 09:15 PM | #2 |
Drives: Fast Join Date: Mar 2015
Best option is buying a large amount of 110 octane race fuel or similar and supplement at fill ups to bring Octane to the 93-95 range. Second best is adding an octane booster at fill ups; the wars on which brand is the best rage on and on. Lastly, the car can function at 91, just not at peak performance levels.
02-25-2020, 09:21 PM | #3 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Can you run E85? Superior to 93 anyway.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
02-26-2020, 09:04 AM | #4 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Is this a DD or weekend toy? If a weekend toy i would order a 5gal of Boostane next time they run a 15% or 20% off with free shipping. That brings the cost to around $8.50 per can and you can play with the mixture. That is what i run. I typically run 8-12oz each time, but i am starting with 93. I use just enough to hopefully keep the KR out. The 5gal will last me a year.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-26-2020, 09:08 AM | #5 |
Drives: CTV5 V Blackwing on order Join Date: Feb 2020
I wouldn’t worry about it. Drove my 2013 C7 with an A&A super charger for 3 years while we lived in Colorado Springs with no ill effects. Your going to lose about 3% of your HP for every 1,000 feet in elevation and not much you can do about it. You can’t change the density of the air
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10 2017 Ford Expedition |
02-26-2020, 09:14 AM | #6 |
Drives: 2017 Camaro ZL1, 6M Join Date: Dec 2019
I've got a similar issue in California, only 91 pump available. Luckily there a few gas stations nearby that sell 100 octane race gas at the pump (and others that sell 5 gallon pails).
5 gallons of 100 octane with the balance of the tank holding 91 octane averages out to about 93 to 94 octane. I haven't dyno'ed the car to confirm but there's a noticeable seat of the pants drop in power when I refuel with straight 91 and the car does feel smoother and has less of a bog effect launching when running above 93 octane. |
02-26-2020, 09:17 AM | #7 |
Meth is a good option. It is a instant octane adder and will cool intake temps. Win win on an LT4. We deal with Alkycontrol and Snow kits.
02-26-2020, 09:29 AM | #8 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
2018 ZL1 1LE - Red Hot, Nav, PDR
02-26-2020, 09:33 AM | #9 |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I would use the 91 octane and buy a bottle of Octane Boost from Advance Auto, Autozone or any parts store and call it a day!
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
02-26-2020, 10:15 AM | #10 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
93 isn't available in CO because supposedly 91 performs about the same at altitude, while not ideal it's not as bad as running 91 at sea level.
I haven't tried adding some 100 octane yet, but I plan on it... Also, AFAIK Octane booster might only increase octane by a tiny amount, adding a can to 91 might not even get it to 91.5.
02-26-2020, 10:21 AM | #11 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
I am in Colorado Springs and run 91 without issue
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
02-26-2020, 11:40 AM | #12 | |
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2) Join Date: Jun 2016
I've noticed when traveling through Colorado that gasoline sold at altitude runs lower octanes (regular unleaded is 85 octane in places) and the reason is air density at altitude. Running 91 will have the same net effect on your car at altitude that 93 would have at or near sea level. |
02-26-2020, 12:41 PM | #13 |
Drives: 2020 ZL1 Join Date: Dec 2019
I I’m vegas and we only have 91 also. You can tell it’s pulling timing even stock and it’s not even hot out yet. It seems like the only non warranty killing option is to run a bit of race gas mixed in but that seems like a hassle for daily driving.
02-26-2020, 12:54 PM | #14 | |
Drives: fast ones! Join Date: Jun 2019
You may want to check out some rebel stations....I've seen some that have 100 octane at the pump. |
