Old 03-24-2015, 06:11 PM   #1
forklord
forklord's Avatar
Drives: 2010 2SS
rocker arm on an angle
is this ok? doesnt look like it. look at the centre of the valve as opposed to the rocker...the tray the rockers sit in looks fine. cranked over the engine a few times and it still sits like this. took it off and reinstalled. same thing
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 03-24-2015, 07:12 PM   #2
1LEMan
1LEMan's Avatar
Drives: 2013 1LE Camaro RS/SS
I noticed a few of my rockers slightly off like you show, but, not quite this far off center. Did you try swapping with another rocker? Perhaps this rocker was machined slightly off from the factory? Swapping it with another rocker will help shed some light. Could swap trays too...
1LEMan is offline   Reply With Quote
Old 03-25-2015, 12:12 PM   #3
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Does it have a trunion kit in it? Looks like the rocker bearing is getting ready to fail.
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 03-25-2015, 02:23 PM   #4
forklord
forklord's Avatar
Drives: 2010 2SS
i tried another rocker on there that looked fine from cylinder 3 and it did the same thing. the tray seat does look a little slanted from the factory after eyeing it up for half an hour. im gonna order a tray and see if that helps. yet ANOTHER wrench in the spokes. good grief.
i do have the trunion upgrade but i tried to twist both rockers gently and they are tight.
Old 03-25-2015, 02:27 PM   #5
forklord
forklord's Avatar
Drives: 2010 2SS
im worried that at that geometry it would do more damage to the valve/seal or cam/rod than the rocker itself.
Old 03-25-2015, 02:30 PM   #6
1sick_eg
Drives: 14 Camaro 1LE,328i, and some Hondas
If you're willing to pay shipping, I'll send you my stock rocker stands for free.
14' Camaro 1LE - Now self-tuned
FRH ported heads, Cam Motion LL solid roller, Jesel rockers, Morel lifters, Kooks headers, Corsa exhaust, ADM intake, Stock compression/bore/stroke
551whp 504wtq
1sick_eg is offline   Reply With Quote
Old 03-26-2015, 10:09 AM   #7
Jayrcr3
Jayrcr3's Avatar
Definitely worth a try.
Possible bent valve??
Old 03-26-2015, 10:45 AM   #8
NicKey
Drives: Nickey Super Camaro
While your at it, check to see if your geometry is good. Determine if the center tip of the rocker is properly positioned in the middle of the tip of the valve at max lift and if the contact is even.
Is there any visible damage to the rocker stand / tray?
NicKey is offline   Reply With Quote
Old 03-26-2015, 12:15 PM   #9
forklord
forklord's Avatar
Drives: 2010 2SS
Ill try a new stand and report back. Im thinking if it was a bent valve i would have had problems before?
Old 03-26-2015, 02:31 PM   #10
cmracing
Drives: 2014 RS/SS
I know nothing about the LS type of engines, though I have 120K on my truck, 30k on my Vette, and 1k on my Camaro.
This I can tell you: The SBC has had crooked rocker arms forever, and ever, yet never caused an issue, even with race engines. I hated that so much I put offset lifters, and offset shaft rockers on my race car engine just so they sit straight!
I'd like to hear from those with experience with these newer engines if GM finally fixed this issue, or it continued.................
cmracing is offline   Reply With Quote
Old 03-26-2015, 04:14 PM   #11
1sick_eg
The rockers are offset, but the rocker tip should still be centered on the valve.
551whp 504wtq
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
