07-19-2017, 06:23 AM | #1 |
Drives: 2017 ZL1 Join Date: Jul 2017
Brake pad REPLACEMENT for less dust
AS with a lot of ZL1 owner, I am tired of fighting brake dust. The brakes on these cars a freaking awesome, but the dust and the dust and the dust and then more dust.
There are several threads on here regarding replacement pads that preform as well as stock but do not create nearly as much dust. These threads are spread out and hit or miss. How about a fresh thread that list pads KNOWN to preform nearly as well as stock and make a lot less dust. THANKS!!!! |
07-19-2017, 08:21 AM | #2 |
Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
sub'd
07-19-2017, 08:29 AM | #3 |
Drives: 2017 Nightfall Gray M6 Join Date: Jan 2017
sub
07-19-2017, 09:26 AM | #4 |
Drives: 2016 Z06, 2017 ZL1 Join Date: Feb 2012
OK, I have had Power stop pads on my C6 Z06, C7Z06 and 2017 zl1. Never had any problems, the dust is cut down at least 90%. part # for the 2017 zl1 are z26-1835 for the front and z26-1053 for the rear.
07-19-2017, 09:32 AM | #5 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
Ditto....Power Stop pads will make you happy
07-19-2017, 09:53 AM | #6 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
Get the wheels ceramic coated. It helps tremendously with cleaning the dust off. I had mine done for $25 a wheel. I apply some wheel and tire cleaner, wait 30 seconds, agitate briefly and then rinse off and the wheels look brand new. All 4 wheels take less than 5 minutes start to finish. With a strong enough stream of water the dust can be rinsed off too but for me agitating with a brush gets a better result.
07-19-2017, 09:54 AM | #7 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
PowerStop Z26
Caveat: DON'T USE THEM AT THE TRACK. |
07-19-2017, 11:37 AM | #8 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Once a week I get out my power washer, and just hit the rims with plain water. Cleans them up so far just perfectly. The black dust residue just rolls off down the driveway.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
07-19-2017, 11:45 AM | #9 |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
+1
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
07-19-2017, 11:51 AM | #10 |
Drives: 2023 2SS Convertible Join Date: May 2009
On the 5th gens, you could get the Cadillac versions of the pads and do much better on dust, but you weren't supposed to take it racing. I would assume that is still true but somebody would need to confirm.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
07-19-2017, 12:02 PM | #11 | |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Friend (kracka) with c7 z51 switched over to Z26s, fantastic results. Zero dust compared to stock. I ordered the same ones, got delivered today and will be doing a lot of flushes soon and plan on installing them when I do that soon. |
07-19-2017, 12:20 PM | #12 |
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto Join Date: Jun 2017
My Powerstops are on the way. Should be installed by the weekend.
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv. 1952 C3100 resto-rod. LS6, 4L60e, 228R cam |
07-19-2017, 02:44 PM | #13 |
Drives: 2017 ZL1 Status "Thank You!" Join Date: Feb 2009
I had the Hawks on my 2012. Excellent. Cost was about $430 all fours corners.
These powerstops are only running about $75 front and $63 rear. Total will be less than $150 all around. Whats the opinion on this in general? The Powerstops seem like a steal. The reviews on them are generally great. Also, where do you recommend sourcing? |
07-19-2017, 03:05 PM | #14 | |
Thread Tools | |
