04-26-2010, 10:32 AM | #1 |
Drives: 300C Join Date: Mar 2010
Pardon my ignorance
But what's the difference between the HP numbers from the factory, 426HP for LS3, and the RWHP I'm seeing on the forums, around 350-370? How much is a cars HP based on it's RWHP?
Seems like everyone just refers to the horse power at the rear wheels but how is that translated to what the engine makes total? |
04-26-2010, 10:37 AM | #2 | |
Drives: 2010 2SS/RS IOM/IOM #3625 Join Date: Jun 2008
666 EVIL RWHP BUILT AND TUNED BY SHIFTED PERCEPTIONS INC.(SPi)
416 Forged Stroker, E-Force Supercharger, Blower Cam, Rotofab CAI, Stainless Works 2" LT Headers and 3" Exhaust, LPE ZR1 Twin Disc Clutch, DSS 1400 HP Axles, Pfadt Performance Kit Stage 3. |
04-26-2010, 10:39 AM | #3 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
The factory measures HP at the flywheel/crank on an engine dyno. Those are the numbers you see advertised. The numbers that count are the rear wheel HP that is done on a chassis dyno. There is a power loss through the transmission and the rest of the drivetrain. Factory numbers are used for marketing. The rears wheel power is used by tuners to measure the power gains after doing mods to the car. They will do a base dyno test to get a starting point, then again after their work is done to see the difference...
04-26-2010, 10:42 AM | #4 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
There is roughly 15% loss through the drivetrain.
So a 426 hp rated at the flywheel would wind up roughly 85% @ 362 ish RWHP. Or you could reverse do the math if all you knew was the RWHP. 362 x 100 / 85 = 426. |
04-26-2010, 10:54 AM | #5 |
Ahh ok I get it. So if I had 400 rwhp then I have about 470 at the crank hp aka bragging rights of 470Hp?
04-26-2010, 11:02 AM | #6 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
there you go.so to know your true HP produced out the rear,you need to have a dyno done on your car.
