08-06-2018, 03:50 PM | #1 |
Drives: 2017 camaro Join Date: Apr 2017
Oil 15%
Is it time for a oil change? next one on sticker says 9000 miles I'm at 7000 but oil life says 15%
08-06-2018, 03:53 PM | #2 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
The % is just an indicator. You should go for an oil change but the engine will not blow up if you go a bit later.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
08-06-2018, 03:58 PM | #3 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Mine was at 33% when I got my car brand new 300 test drive miles on the odometer -- it had been sitting outside for a year though unused for the most part.. ...know what my dealer did?
Salesman: That can't be right! *resets oil life counter*....there you're good to go! Let us know if you have anymore problems! |
08-06-2018, 04:01 PM | #4 |
Drives: 2017 2lt rs Join Date: May 2017
Get it done
08-06-2018, 05:01 PM | #5 |
Drives: 2017 Camaro 1SS Convertible Join Date: Jul 2018
Run it until it's 0%.
Experience 15 years in car business. As long as you don't reset it for giggles it should be pretty accurate. In fact it always errors on the side of caution. So changing at 15% you probably still have a lot of life left in that oil. https://www.edmunds.com/car-care/oil...g-systems.html
17' Camaro 1SS Vert - Plastidip for 50 Hp gain.
08-07-2018, 12:45 AM | #6 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Changing it early is not going to hurt anything. It's probably better for the engine to get the old oil out. My mother-in-law has a Cadillac with free oil changes and they told her to come in when it gets to 20%. I usually don't go over 4000 to 4500 miles.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
08-07-2018, 12:48 AM | #7 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
depends. When did you do your first oil change?
08-07-2018, 01:29 AM | #8 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
08-07-2018, 06:17 AM | #9 |
Drives: 18 zl1 Join Date: Aug 2017
mine usually says around 60% when I change it
08-07-2018, 08:39 AM | #10 |
08-07-2018, 08:45 AM | #11 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
GM Oil life % is calculated between miles and time since last change...maximum time of 12 months....i wouldnt risk resetting oil life without oil change....i could see someone going 13 months on oil (even though the mileage is less than reco oil change), having some unrelated engine failure and having GM deny warranty
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
08-07-2018, 10:58 AM | #12 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I believe it says as soon as it tells you to change it do it within your next tank of gas.
08-07-2018, 11:11 AM | #13 | |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
08-07-2018, 11:53 AM | #14 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I'm old school (and just downright old). We used to change our oil every 3,000 miles or so as a rule of thumb.
On my 2013 ZL1, I've always opted to get an oil change whenever the oil monitor shows 50% oil life left, which usually is right around 3,000 miles. This usually results in 2 oil changes per year or so. Yes, I could wait till life drops much further and save some money, but I don't mind the cost of two changes per year. Cheap insurance. |
