08-26-2019, 11:22 AM | #1 |
Drives: Chevy Camaro ZL1 Join Date: Aug 2019
2018 ZL1 CAMARO INSTRUMENT CLUSTER ISSUES
Has anybody had issues with instrument cluster, oil pressure and temp gauges reading incorrect info. They just put a new engine it, Its been at the Chevy Dealer for 95 days and no instrument cluster available.
08-26-2019, 11:28 AM | #2 |
Drives: 2013 ZL1 Join Date: Mar 2013
This is the Gen5 page you need to go to the Gen6 page and someone there might be able to help you. They would own the car if it was mine. Make GM take it back if they can't get the part. Also there was a thread somewhere where they had a ground problem. Put a extra ground wire on it from the motor to the frame. Maybe that will fix the gauges. It seems to have worked for others.
