03-18-2022, 06:37 PM | #1 |
Drives: 2013 Camaro 1LE 1SS/RS Join Date: Jul 2013
OEM shift knob part number help
It's time for me to replace my suede/alcantra black (or is it considered dark grey?) and light grey stitching shift knob on my 2013 1LE.
I've been running searches and seems I found the number for the 2014, but it says that it's incorrect for the 2013. I can't find it for the '13 model. Anyone have a good GM part number for this? Thanks. |
03-19-2022, 12:22 AM | #2 |
Tri-County Camaro SWFL
13-15 are the same. The only difference between years, early models twist off and 13+ use a set screw to hold the knob. I believe its black with stone stitching. Z/28 should be the same as well.
https://www.gen5diy.com/collections/...32173250052207 is this the number you get when you look up the 14/15? 24267674
03-23-2022, 05:58 PM | #3 |
Correct. Did they just stop making the one for a '13? Seems like a part number should still exist. I just can't seem to find it.
03-23-2022, 11:24 PM | #4 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I replaced the knob in my 2013 a couple of years ago. I seem to recall having a hard time finding the part number on my own, so I just called the dealer and gave them my VIN. I ordered 24265938 which was the correct 1LE stitching.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
