Old 09-13-2019, 07:16 AM   #1
scorpsteals
Drives: Dodge
Audio shutoff 2013 2LS
I have a 2013 Camaro 2LS and the audio stopped working completely no lights and completely blank.
I had a minor accident a week before while reversing the car around the fuel and bumper area but the audio was running fine for a week after the accident. Initially I thought the cables around the fuse area may have become loose but the body shop guy says the fuses are all fine and they are not sure what's causing the issue since they are not electronics experts.
Any idea what could have gone wrong and how to fix it.
Thanks.
scorpsteals is offline   Reply With Quote
Old 09-16-2019, 12:40 PM   #2
buckholt82
Drives: 2010 camaro
facing the back off the car your amp if you have one should be on the left side. so maybe if that was the spot that got hit then some wires could of got pinched.
Sent from my SAMSUNG-SM-N920A using Tapatalk
buckholt82 is offline   Reply With Quote
Old 09-17-2019, 01:51 PM   #3
scorpsteals
Drives: Dodge
So I disconnected the negative of the battery and reconnected after 20 min's and the audio came back on couple of days ago. However when I start the car I heard loud disturbance from the stereo for a split second and the audio continued to work fine until yesterday when the audio turned off again completely.
Old 11-05-2019, 08:45 PM   #4
Jerry5thDan
JANET'ss
Jerry5thDan's Avatar
Drives: JANET- 2010 SS Dealer Factory Z28
Same here, heard a loud disturbance and popping sound, then nothing, then it came back, now I only have very quiet sound with the volume turned all the way up on the right side only. I think its the AMP. took the whole damn car apart wiggling and checking every connection. Signal coming from amp seems to be the stopping point.
Jerry5thDan is offline   Reply With Quote
Old 02-12-2020, 11:02 PM   #5
Jerry5thDan
JANET'ss
Put new double din in ssme amp allgood, ? The Boston acoustic system is awful. Cheapest BOSS on Ebay is better
Sent from my SM-G960U using Tapatalk
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
