#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 08-01-2023, 09:43 PM   #1
Ryder019
Drives: 2016 2SS
Help! Loud Engine Tick, Engine Knock Sensor
I have a 2016 SS with about 80K miles on it. About 2k miles ago, the oil pump went out and was replaced. Now I have an insanely loud engine tick after punching it one time. Also, the CEL came on with an "Engine Knock Sensor" code. Assumed a lifter, however after removing the valve covers, all the rocker arms are still rock solid. Could this still be a lifter or something different all together.
Ryder019 is offline   Reply With Quote
Old 08-04-2023, 12:24 PM   #2
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
How did you evaluate each of the lifters have movement and aren't stuck? Did you rotate the crank and observe movement of each lifter?
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Build Log: https://www.camaro6.com/forums/showt...6#post11353116
keep_hope_alive is offline   Reply With Quote
2016 ss, cel, fuel pump, lifter, tick
