02-24-2014, 11:22 AM | #1 |
Drives: 2010 2SS/RS Join Date: Sep 2011
RDS blower Plates for the LSA and LS9
We have proved the gains on our Maggie max packages for the various 112/122/1900/and 2300 Eaton based blowers Removing Heat soak from the LSA and LS9 style blowers will also net more hp! Just wrapping up the NEW RDS LSA/LS9 blower plates. dyno testing will commence soon.. Last edited by Ray@RDS; 05-14-2014 at 06:09 PM. Reason: add video |
02-24-2014, 07:04 PM | #2 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Excellent. Let me know if you need a test car for a ZL1. I met you last Summer at Har Mar. Is that a phenolic plastic? Also, what's the price and IAT2 temp drops?
02-24-2014, 07:50 PM | #3 | |
I remember, your ride is one of the reasons I finished developing these! Already have one going on an orange beast, would love to compare them on the dyno this spring, welcome to bring your ride by the shop. We can talk about install and tuning it in the dyno. Ray |
02-25-2014, 11:41 AM | #4 |
Could you elaborate more on what this mod does. I have a short list of things I want to do to my car and if this will reduce heat or increase hp Id like to know how or why it's does.
Thanks in advance.
Laus Deo
02-25-2014, 01:14 PM | #5 | |
Keeping them is always a good thing. |
02-25-2014, 04:48 PM | #6 |
Drives: 2013 silver ZL1 Join Date: Apr 2013
02-25-2014, 07:03 PM | #7 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I can see how this product would help in situations where short periods of boost are used but I know from first hand experience road racing my car that if you stay in the throttle at all the supercharger spinning at 20,000+ rpms becomes the hottest item under the hood. In that case you may want some heat transfered to the motor and this item would not help.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
02-25-2014, 07:31 PM | #8 |
I have an entire day on the dyno @ Dallas performance that says different, as long as air is passing thru, heat soak is not the issue. When the engine stops it heats up, that's natural heat rises. Start the engine open the throttle blade, it starts to cool down.btw I live in MN drove my Camaro down last summer 1/4 mile tested Texas motor plex, then dyno pulled the entire weekend drove it back. Stay tuned ! Another major magazine has picked up this for another feature article. I also helped create that 102 TPIS tb you are running... I e it was me and a few guys collaborating it's creation, I still currently run the first ones, boys in UAE RUN THE FISRT FEW.my lsx 427 was the first to break 700 to the wheels in a bus back in 08, 62/90/112/122/1900/2300 and I go way back
They do work, may not be a cure all, we both know every little bit helps to have fun . |
02-25-2014, 08:34 PM | #9 | |
Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
I think a little wik down the 1320 it will help. Road course/ auto cross probably not. |
02-25-2014, 08:58 PM | #10 | |
Speed Freak
On a hot day I can take any ZL1 that has not had an extreme supercharger coolant system upgrade, put in my obd bluetooth and read IAT 2 and within 8 minutes (I'm being conservative) of flat out road racing show timing pull from excess supercharger heat, while all of the block oil and water temps will be fine. If you see temps going down when you open the throttle blade then you are not running long enough on the dyno at high enough rpms and boost to generate the supercharger heat. Most dynos don't have near enough fans to keep anything cool so the engine coolant may over heat before you see the supercharger heat. With real air moving over the car, the supercharger water overheats way before the engine water. I think you need to test somewhere where you actually make boost besides a dyno. Not cruising down the interstate and not in a 12 second 1/4 mile pass. I have actually got IAT2 so hot it shut the engine off. That was before I had anything to monitor it and I had to read the code once the car shut down. This does not happen from "heat sink" it happens from blower heat generated with sustained boost. So once again, I think your spacer will help if you are doing short bursts of throttle like in a drag race or a dyno run but in real world road racing it may actually trap heat in the supercharger that otherwise might be dissipated in the engine coolant systems. On the other hand you did a really good job with the throttle body, thanks.
02-26-2014, 08:05 AM | #11 |
Drives: Camaro ZL1 Join Date: May 2012
I can see this helping with staging lanes. Far too often, if the line is long, i shut the car down. When fire back up, the IAT2s have climbed 20+ degrees.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
02-26-2014, 08:20 AM | #12 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
I also think that on a road course everything gets hot within a few minutes. Might slow it down a bit though. But the supercharger heat doesn't come from transfer out of the heads. It comes from the compression of the air. That compression still is going to heat up the air, that's just simple physics. I think this mod essentially gives you longer runners and therefore may move you torque curve a bit. And since you're compressing the air into a larger volume (bigger runner) it might not generate quite as much heat.
Bryan 2018 ZL1 M6
02-26-2014, 10:53 AM | #13 | |
Ok, thank you one more stupid question. I assume that this will raise the height of the blower. Will there be any clearance issues, rather will the hood close without modification?
Laus Deo
02-26-2014, 11:00 AM | #14 |
