Old 03-04-2014, 02:09 PM   #1
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Do you let your engine warm up?
Just curious about how many let your engines warm up before you drive her. Luckily i have a garage so i start her then go back in shave brush my teeth and go to work.When i leave work i start her and gently wipe her down from the days dust.I couldn't imagine just jumping in a car and driving right off.I generally don't put in gear til i see 147 degrees.If this has already been covered,sorry.I did a search and a page came up but nothing about warming up your engine.
cornerspeed92 is offline   Reply With Quote
Old 03-04-2014, 02:14 PM   #2
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
garage here also. Maybe 30-45 seconds and drive easliy for 5 minutes. Modern cars for along time now can get away with that vs the old days
VR Baron is online now   Reply With Quote
Old 03-04-2014, 02:16 PM   #3
King Nothing
Under a Peterbilt
Drives: Rogue, Durango and Camaro
^yup! I usually let mine idle for 1-2 minutes then drive easy till I hit the freeway 7 miles away
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 03-04-2014, 02:17 PM   #4
BasedSS
BasedSS's Avatar
Drives: 2014 SS
Garage as well, usually will give it about 10min
2014 SS Stainless Works Headers w/ high flow cats, Stainless Works Retro Chambered Exhaust, Jannety Tune, Hurst short throw, APEX catch can, Tampa Tunning Throttle Body, APEX/Gen5 LED fogs, CAI Intake system, Diode Dynamics LED's, ACS T4 Splitter
BasedSS is offline   Reply With Quote
Old 03-04-2014, 02:19 PM   #5
LBreezie
LBreezie's Avatar
Drives: 2012 Camaro 45th anniversary
depends if im in a hurry, then no. If i was in no rush then i will let it sit until the idle smoothes out then ill use it however i like.
LBreezie is offline   Reply With Quote
Old 03-04-2014, 02:33 PM   #6
TOYMARO
TOYMARO's Avatar
Drives: 2011 Camaro SS/RS 2SS
Garage.
On a hot summer day. A few minutes max. Drive easy for a few then all is fair.
A nice cool fall day. Lets say 50 F. Between 5-10 minutes. Then again drive easy for a few.
To me its more about warming all the aluminum that the motor is made of slowly dependent on ambient air temp.
TOYMARO is offline   Reply With Quote
Old 03-04-2014, 02:34 PM   #7
flyinlow
flyinlow's Avatar
Drives: 2017 Camaro ZL1
Idle about 30 seconds to build oil pressure and then drive it easy until all the temps are up to normal
flyinlow is offline   Reply With Quote
Old 03-04-2014, 02:35 PM   #8
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Garage I usually wait until the trans temp starts to get close to normal then it's game time.
Trob85 is offline   Reply With Quote
Old 03-04-2014, 02:38 PM   #9
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
The best thing for an engine is to get to operating temps under no more than a low load as soon as possible. You are not doing your engine any favors by letting it idle and warm up. Start you car, put it in gear, and drive in gently until it has reached operating temp. This is better for it than the long warm up at idle.
gajagfan is offline   Reply With Quote
Old 03-04-2014, 02:49 PM   #10
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Well this is a frequently asked question and my answer is: I crank it up and let it run about a minute to get the oil flowing - then I drive it easy for two or three miles or so. Then she's ready to keep up with traffic. I never punch 'er up until the temp guage is at normal - summer or winter.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 03-04-2014, 02:51 PM   #11
Manbearpig
Engineer of softness-ware
Manbearpig's Avatar
Drives: 2013 2LT RS
I start it up, get in and drive gentle for about 5-10 mins, far as I know as long as you aren't gunning the engine and going 0-80 rapidly the car will be fine as it warms up. Certain fluids won't warm anyway until the car is moving as apposed to being idle.
Manbearpig is offline   Reply With Quote
Old 03-04-2014, 02:52 PM   #12
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
Usually idle 1-2 mins, go easy for a little bit.
BooSSted is offline   Reply With Quote
Old 03-04-2014, 02:55 PM   #13
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
I'll start mine up and let it idle for 3-4 minutes then take off. However, I try not to run the engine past 2500 until the oil temps get to at least 180*. The coolant temp will rise fairly fast, but it's the oil temp that is most important IMO and it will take forever to get warmed up unless you drive it.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 03-04-2014, 02:57 PM   #14
trashmanssd
trashmanssd's Avatar
Drives: Black 14 2SS/1LE/RS 14 Tundra
Yupp, trans will warm slightly but diffs wont at all. Mines garaged so 1-2 minutes to let oil get flowing good then drive it easy till oil temps over 180. Then I get to do 20-40 spiritedly all 1.5 seconds of fun.
trashmanssd is offline   Reply With Quote
