11-10-2019, 06:19 PM | #1 |
Drives: 2012 Camaro 2LT Join Date: Oct 2019
Installed Elite Engineering Catch Can
I just installed the catch can on my 2012 lfx. Is it supposed to be making a little hissing sound out of the can? It sounds more like air coming out.
11-10-2019, 06:43 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Yeah, mine has always sounded like it has a vacuum leak. It doesn't because all the fittings are sealed but I assume that's how it's supposed to be.
11-11-2019, 02:53 AM | #3 |
11-11-2019, 11:11 AM | #4 |
That could be the direct injection system. It is a distinct "tick" noise.
11-11-2019, 12:03 PM | #5 |
12-07-2019, 08:36 AM | #6 |
Drives: 2012 2LT/RS Join Date: Oct 2011
That ticking noise might be the purge valve.
12-07-2019, 01:25 PM | #7 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
Direct injection ticking and purge valve ticking are both normal.
12-25-2019, 11:42 AM | #8 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Which can did you go with? 2 port or 3? I've been trying to get in contact with Elite Engineering but when ever I call they are "on the other line" or "in the shop". Got a generic email response from them but I'd like talk to someone since I have several technical questions.
12-26-2019, 04:31 PM | #9 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
I went with a 2-port catch can
12-29-2019, 01:59 PM | #10 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
I installed the Elite Engineering 2-port can several months ago. Install was easy, and it's captured quite a bit of oil and gunk since then.
I, too, just noticed the hissing sound recently. Not sure why I hadn't noticed it before. Anyway, from what I've read online, the manufacturers claim that some noise may be heard from the air pressure within the hoses, especially on longer hoses. I haven't noticed any performance issues with my car. The hoses seem tight and clamped down to me, and the can is screwed on tight as well, so I've just disregarded it. |
01-04-2020, 05:55 AM | #11 |
Drives: 2012 1LT Join Date: Nov 2015
2 Port here, and it's catching quite a bit of oil.
01-05-2020, 05:17 PM | #12 |
CAMARO RS M6
Drives: Camaro RS v6 2014 M6 Join Date: Jan 2019
I have catch can elite and really works I love its
01-05-2020, 06:11 PM | #13 |
Drives: Never just fly under the radar Join Date: Jul 2015
I have the same hiss since install a few years ago. Tried several different setups with the vacuum lines and nothing helped. Spoke with them at Elite a few times and they tried to help and even sent some new clamps to try. Just got use to the hiss and after seeing the sludge it captures wouldn't run without one. Have one on my SS to but it doesn't seem as necessary since it's not DI. Don't ever capture much in it but still keep running it.
Old Skool |
01-05-2020, 06:54 PM | #14 |
CAMARO RS M6
I post video on YouTube elite catch can and see how much oil capture I love this elite really do the job
