#Camaro6
AWE Tuning
Old 11-19-2018, 02:12 PM   #1
mgb
mgb's Avatar
Drives: 2010 ABM 2SS - 2012 ZL1
2018 19" Wheels
What are the dimensions on the 2018 Zl1 18" wheels? Front and rear width, offset, and backspacing. Will they fit my 2010 SS?
mgb is offline   Reply With Quote
Old 11-19-2018, 06:15 PM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
There's no 18" offering for ZL1s. There's only 20" on the regular ZL1 and 19" on the ZL1 1LE.
Specs for 20" are
20x10 front
20x11 rear
Specs for 19" are
19x11 front
19x12 rear
The 20s will fit on your 2010 SS as they're the same specs as 5th gen SS 1LE and ZL1. The 19s might fit, but you'd probably have to have it set up just right.
Can'tHave2MuchHP is offline   Reply With Quote
Old 11-19-2018, 06:16 PM   #3
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
18"? On a ZL1? The standard ZL1 has 20s, the ZL1 1LE has 19s.
Which model has 18s?
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 11-19-2018, 08:08 PM   #4
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
None. Only custom.
Pollock is offline   Reply With Quote
Old 11-21-2018, 08:35 AM   #5
mgb
mgb's Avatar
Specs for 20" are
20x10 front
20x11 rear
Specs for 19" are
19x11 front
19x12 rear
What do you mean by set up just right?
Old 11-21-2018, 08:36 AM   #6
mgb
mgb's Avatar
Sorry - please don't stone me!
I meant 19's. Sorry for the confusion
Old 11-21-2018, 08:43 AM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
LOL... I fixed the title
Old 11-21-2018, 09:06 AM   #8
wlsmoku
Drives: 2018 ZL1 A10
1LE:
19x11 +11mm OS front (same as 14/15 Z28 front)
19x12 +41mm OS rear
ZL1:
20x10 +20 front
20x11 +43 rear
wlsmoku is offline   Reply With Quote
Old 11-21-2018, 09:13 AM   #9
Markoz28
Drives: 18 ZL1 nightfall grey A10
I think he’s talking about back spacing. But stock I don’t think they will fit.
Markoz28 is offline   Reply With Quote
Old 11-21-2018, 10:52 AM   #10
Can'tHave2MuchHP
Drives: Fast
What I mean is, on 6th gen SS 1LE and ZL1s, people are getting away with OEM ZL1 1LE 19" wheels but they have to have street alignment and possibly a small spacer. I'm not sure if that applies to 5th gens, I actually THINK that 5th gens have a bit more room for height and even width, but I'm not sure about depth which is where the ZLE 19" wheels start to pose a problem with internal rubbing. Again, no way to know until you drop the dough or get lucky enough to find somebody who will let you bolt a set up.
Old 11-24-2018, 03:15 AM   #11
mgb
mgb's Avatar
So I need a wheel with less backspacing or run a spacer? I also have Eibach coil-overs, reckon that will make it even worse?
Old 11-24-2018, 07:02 AM   #12
Pollock
LT4 M6
Pollock's Avatar
I saw a thread where a guy did it. Not sure aboout the details.
