Old 05-27-2010, 02:44 PM   #1
quinthawk
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1
Spark plug question
I have a maggie on my camaro (auto) with the 3.8" pulley, headers and airraid intake. Should I keep the stock plugs or switch to a colder plug like ngk tr6?
quinthawk is offline   Reply With Quote
Old 05-27-2010, 02:53 PM   #2
99-LS1-SS
Waiting...
Drives: 2009 G8 GXP M6
The NGK TR6 was recommended to me. I have the same basic setup as you. I gapped mine at 0.035 and they seem to be fine.
SOLD 2009 Maverick Silver G8 GXP M6
Engine Mods: TVS 2300 Magnacharger 6.5lbs, ARH 1 7/8" long tubes with catted x-pipe Roto-Fab Intake, Custom Fuel System, Tuned by Me
Drivetrain Mods: Stage 4 Monster Clutch, GForce 300M Race Axles
Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms and toe rods
Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
99-LS1-SS is offline   Reply With Quote
Old 05-27-2010, 04:34 PM   #3
quinthawk
Thanks
Old 05-27-2010, 04:56 PM   #4
onechuck
Onechuck
onechuck's Avatar
Drives: 2010 Camaro IBM 2SS\RS SC & Cammed
How does the Airraid hooked up to the maggie? Was it an easy hookup, I am about to get mine done and was told it may be tough to do. Did you use the Airraid tube or did you have to modify something. I would love to see a picture of this. How does it run?
onechuck is offline   Reply With Quote
Old 05-27-2010, 04:59 PM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Definitely run a colder plug. A NGK TR6 would be a very good option for you and it is what we use on our 2010 Camaro with the TVS2300.
Old 05-27-2010, 05:04 PM   #6
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
i figured a colder plug was needed, but a well known speed shop on this forum told me (over the phone) it was not needed. my instinct says it cannot hurt, except for a touch of mileage.
my other car was running 13 lbs boost, and n2o, i ran a .032 gap on one step colder.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 05-27-2010, 10:01 PM   #7
quinthawk
I used the magnuson tube and I cut off the tube section of the stock intake (the part of the stock intake that has the opening to bolt in the air flow sensor), I then used the airraid couplings and one of the magnuson couplings to clamp the tubes to the airraid filter. Car runs great. I think the airraid tube would work if it was trimmed a little bit.
Old 05-27-2010, 10:14 PM   #8
BlownChevy
Drives: 2015 1SS RS 1LE
Been using the stock plugs in all of my vehicles since the blowers went on......I have yet to find a need to change them.
BlownChevy is offline   Reply With Quote
Old 05-31-2010, 01:03 AM   #9
dracer98
Drives: 2010 Hugger Orange
Agreed - no need to go colder - GM picked the plug they did for a reason. The quench on the LS3 heads is such that the stock plugs at fine with even 10psi of boost. This assumes the correct tune is in the car
dracer98 is offline   Reply With Quote
Spark Plugs Rod10269 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-25-2010 05:33 PM
Quick question about adding amp / sub to base system B_RADiculous Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 2 04-23-2010 01:40 PM
Question Involving 4.10 gears & Bushings Deric884 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-13-2010 06:53 AM
Points Ignition Thoery Question fuffl General Automotive + Other Cars Discussion 3 01-10-2010 02:41 PM
