11-11-2013, 04:05 PM | #1 |
Drives: 2013 Camaro 1SS/1LE Join Date: Feb 2013
305/35/20 All Around
So I really like the Goodyear Eagle F1 G2's, they are very predictable and grippy in the warm. I don't remember seeing a thread on it but has anyone ever tried running a 305 square setup? what needed to be changed in the front end?
I am going to be running Time Attack next year and was thinking of going this route. I am also adding a LG G6X3 Cam Package, TSP Headers, OffRoad Pipes and Exhaust and will want the extra grip. |
11-11-2013, 06:33 PM | #2 |
Drives: Victory Red 2013 Camaro 2SS/RS 1LE Join Date: Oct 2013
I've seen pics of 305's all the way around, and they stick out about an inch in the front. If you look closely at the Z28, it has fender flares.
11-11-2013, 06:38 PM | #3 |
Drives: 14 1LE Join Date: Mar 2013
It may be too much for the front wheels, I'm sure you could go 295 35 20 without too much difficulty.
LMS Engineering
11-11-2013, 07:43 PM | #4 |
Drives: 2014 1LE Join Date: Sep 2013
Anybody try running the rear wheel up front? Will it clear the strut?
11-11-2013, 08:12 PM | #5 |
Drives: 18 ZL1 1LE Join Date: Apr 2013
I'm going to imagine with the current setup you would have some rubbing issues when you turn the tire all the way. You could turn the wheel all the way & both directions & see if you can see how much clearance is back there. 305s are some really wide tires, especially up front. The z28 rims probably have a different offset than the ones we have up front.
11-12-2013, 01:54 AM | #6 |
Drives: Black 2011 2SS/RS Join Date: May 2011
Pedders runs 305/19 square setup on their car. They use Forgeline wheels with a 'special' offset. You can get the same setup. PM Nine Ball on this site and he will hook you up with whatever combo you need. FYI he told me that with that setup I would be throwing a lot of gravel on my car so its not optimal for a DD. I'd like to get the fender flares the Z28 has so I can run that wheel/tire combo.
11-12-2013, 06:14 AM | #7 |
Sellin Chevy's since '06
I've heard 305/20s wont fit on Camaros(up front). That's why Pedders and GM went with 305/19s
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
11-12-2013, 06:22 AM | #8 |
Banned
Drives: 2010 2SS/RS Join Date: Feb 2012
I'm running 295/35 up front with a 20x10.5 rim and they fit perfect no rubbing and stick out. I think 305 would be pushing it
11-12-2013, 11:51 AM | #9 |
SparkyDL75
What are the offsets on your wheels? I would like to get a 295 or maybe 305 on the front also.
2010 CGM 2SS/RS M6 LS3 Black/Gray
Exterior American Racing BLVD Black w/Machined(20x10) Mickey Thompson Street Comps(275/40 & 305/35) Suspension Pedders Pace Car Pkg w/ZL1 Upgrade; Pedders Upper & Lower Control Arm, Steering, & Differential Mount Bushings; Pedders SS Brake Lines; Pedders Dual Bearing Camber Plates; ZL1 Toe Link; Hawk Performance Ceramic brake pads Drivetrain Maggie2300(8psi-3.4pulley); CompCam; 85lb injectors; ZL1 fuel pump; ZR1 MAP; Centerforce DYAD Twin Disc clutch; Stainless Works LT headers; QTP Cutouts; Rotofab intake; RX catch can; Mike Norris tune 643rwhp 598 rwtq |
11-13-2013, 12:35 AM | #10 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
The L/28 runs 305/35-20's
