#Camaro6
AWE Tuning
Old 03-28-2024, 01:03 PM   #1
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Modified All Bolt On's
any reason NOT to use recommended oil...
So, I have an open "Free oil" change with a GM dealer from when I bought my car. I've not used it, and don't plan to because I don't want my car in shop unless absolutely necessary. With that being said, I changed my own oil at 500 miles and ready to change it again at 2700 miles. Last time I used Mobil 1 Supercar Full Synthetic 0W-40 and a ACDelco PF64 filter. Would there be any reason to select a different oil vs just stick with what I've been using?
Thanks
2023 ZL1 A10 - CSP 2" Long Tube Headers by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port/Polish w/Griptech 2.3" Upper | Granatelli Malevolent Coil Packs | Granatelli 0 Ohm Plug Wires | Katech Valve Covers w/Coil Relocation | FI Interchillers Blower Spacer Plates | Mighty Mouse Mild | JMS Flex Fuel Booster | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | AEM w/b AFR | Banks iDash Data Monster | HPTuners MPVi3 Module and Licenses (ECU & CCM) | Remote Tuned by Ted at JRE
2023_ZL1-AUTO is offline   Reply With Quote
Old 03-28-2024, 01:07 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
No reason unless you’re gonna track your car or go with the recommendations after being highly modified
CalgaryZL1 is offline   Reply With Quote
Old 03-28-2024, 01:11 PM   #3
2023_ZL1-AUTO
Sooo, no tacking. But any harm in going 5W50 anyway? I don't drive my car when the are less than 40°!
Old 03-28-2024, 01:18 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
The lighter weight oils will get into your internals faster, if you’re not abusing your engine stick with the lighter weight, like 5-30 if 0-40 gives you concern
Old 03-28-2024, 01:19 PM   #5
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
If you’re doing your oil change then go with the factory suggested brand and weight. I do my oil changes and use Lucas 5w30 and either a Mobil 1 or Napa Gold filter. That’s just me though.
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
LT4Greg is offline   Reply With Quote
Old 03-28-2024, 01:20 PM   #6
2023_ZL1-AUTO
THANKS, I'll go 5W50 ! Abuse ha! That's a subjective word !!!
Old 03-28-2024, 01:26 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
You know what I mean, for example, we run 50 weight oil in our diesel engines at work that run all day every day. But upon fire up, they sound like a bag of marbles before they warm up.
Old 03-28-2024, 02:32 PM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Send samples to Blackstone-labs and pay the extra for the TBN ($45). Gives your grandkids a great documented provenance on the original survivor numbers matching engine
Gunkk is offline   Reply With Quote
Old 03-28-2024, 02:49 PM   #9
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Once I put the higher viscocity oil in for a track day that is when my oil pump started to fail.
I ran about 3 morning sessions and had to leave due to the tires becoming shredded on the outside face.
I drove home then changed the oil the next day but the damage was already done.
Then there is chevy to worry about.
The chevy field technician said that the oil filter was installed "incorrectly" and i had the wrong oil in it.
The pump failed, and when pressed Chevy said that they will only pay 30% of dealer invoice for repair because I tracked the car, installed the oil filter wrong and used the wrong oil; which is BS.
Proceed at your own risk.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 03-28-2024, 02:57 PM   #10
CalgaryZL1
CalgaryZL1's Avatar
With your year, it is a concern. With a 2023, and with this so-called upgraded pump with warranty, why would you put 50 weight, other than track or the suggested oils for highly modified engines.
Old 03-28-2024, 03:28 PM   #11
2023_ZL1-AUTO
That's what I was asking ! So just stick to recommended 0W40 !!! I'm good with that !!!
Old 03-28-2024, 03:50 PM   #12
CalgaryZL1
CalgaryZL1's Avatar
Yes! Unless you are going to track the car or highly, modify your engine and use the recommended oil, I thought I said that already. I thought my first time suggestion would set in.
Old 03-28-2024, 03:56 PM   #13
CalgaryZL1
CalgaryZL1's Avatar
Sorry, I am old and impatient
Old 03-28-2024, 03:58 PM   #14
CalgaryZL1
CalgaryZL1's Avatar
You can’t teach…….
