05-30-2017, 03:00 PM | #1 |
Drives: Black 2012 ZL1 Join Date: Mar 2013
Can't switch PTM modes
Recently I noticed that I can't switch modes when I press the button. When I push the buttons the light will change (from tour to sport or vice versa) but I can't access any of the modes no matter what I do.
A few weeks ago I did get a service stabilitrack message when I started the car but I've seen that happen when I let it sit and the battery gets low. Not sure if the 2 are related. How can I get my modes back? |
05-30-2017, 03:30 PM | #2 |
KaBoom1701
Disconnect battery and let sit 30mins. Reconnect and see if the helps.
Any ecu codes?
Mods:
05-30-2017, 09:34 PM | #3 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
You are double tapping the traction control button and nothing happens?
I saw a thread last year I think where someone had same problem and the switch had been put back together backwards somehow by someone.
Bryan 2018 ZL1 M6
05-30-2017, 11:08 PM | #4 |
"BEASTM*DE"
Push the traction control button twice...PTM should show in the DIC...Choose mode by pressing tour or sport buttons...Tour goes back, sport goes forward...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
05-31-2017, 07:41 AM | #5 |
Nothing has been done to the car. It was working then at some point stopped. I'll try disconnecting the battery (hopefully tonight).
05-31-2017, 09:56 AM | #6 |
KaBoom1701
Well try the simple stuff like battery reset and maybe pull the switches from the panel and make sure no wires have come loose.
Weird
Mods:
05-31-2017, 10:09 AM | #7 |
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS Join Date: Oct 2016
like others have said, you have to push the button to the right of sport mode twice so traction control is off ,or just hold it down for 7 seconds, then you should be able to see ptm modes
2017 C7 Z06
2013-ZL1 2017 HELLCAT SOLD 2019 HELLCAT REDEYE WB 69-Z28, LSA SWAP, T56 MAGNUM 71-CHEVELLE SS, 496 STROKER TH400 |
05-31-2017, 11:11 AM | #8 | |
05-31-2017, 11:41 AM | #9 |
Drives: 2013 ZL1 M6 Join Date: Sep 2016
I have the same issue with mine. It stopped working after I had the car dynoed. I was going to take the cluster apart and take a look at the switch. I can turn the TC off but I can't choose any of the 5 PTM modes.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP 630.35 RWTQ |
05-31-2017, 04:21 PM | #10 |
KaBoom1701
I bet they messed with the ride sensors under the car when they strapped the car down.....
Mods:
05-31-2017, 05:58 PM | #11 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Just a note here, convertibles don't get the PTM's only the coupes have them.
06-01-2017, 07:42 AM | #12 |
Unplugging the battery did it for me. Good to go.
06-01-2017, 07:43 AM | #13 |
How long did you leave it disconnected for?
06-01-2017, 09:14 AM | #14 |
KaBoom1701
Glad it worked!
Mods:
