02-24-2016, 09:18 PM | #1 |
Drives: 2016 camaro 2ss npp, A8 Join Date: Feb 2016
SS A8 launching techniques
I was wanting to see what techniques A8 owners are using to get off the line the best. Stabilitrac and Traction control off or on? Preload or leave from idle? Do you change things depending if your at the track or just on the street?
My last sports car was a turbo awd 5spd so I'm in a totally different world! I've only had the car just under a week. Love it and had a first race against 2015 mustang gt. Killed him easily and i didn't change any settings or preload. I was even is touring mode! I know track mode will help as well. So what's everyone's opinion? |
02-25-2016, 10:42 AM | #2 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
1. Tire pressure at 20psi
2. Traction off and in sport mode (didn't see any diff from stability on or off) 3. Go around water box and line up in the sticky stuff, do a slow burn at 30-40mph for a few seconds to get the tires sticky. 4. Stage In the tracks of the sticky stuff and launch hard from idle. 5. 1.7 60' times are possible without DR's.
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
02-25-2016, 11:00 AM | #3 |
Drives: Current Camaro-less Join Date: Jul 2014
Don't do a true burnout on street tires. Just spin them for a second or two to clean off any sand, pebbles or other twigs. if you're spinning them to the point where smoke is visible, you've done too much.
Street tire compound gets more slippery and slick when warm, not stickier. Save burnouts for DR's. |
02-25-2016, 06:03 PM | #4 |
Thanks for the tips!
02-25-2016, 06:49 PM | #5 | |
Drives: Used to Drive Blue Camaros Join Date: Oct 2008
If that doesn't work, try this: I drive around the water and then back into it, hit the throttle to spin out of the water box, and then do the burnout exactly as described. I do it this way to reduce the driveline stress rather than starting the burnout on a somewhat dry surface. If the track surface is poor, do the same thing but hold the burnout until you see smoke in the rear view. Get the tires really hot and then drive up to the line without any further drama. This not my first choice but it works - and you leave about 500 miles of rubber on the track and in the wheel wells. For bracket racing, do everything the same but do a quick, hard, no smoke dry burnout to clean the crap off the tires, use launch control, and focus on consistent (but 2-3 tenths slower) runs. Last - if you get wheel hop - back off because that run is over. No reason to damage the track or the car. Drive back into the staging lanes and do it again. |
02-26-2016, 12:16 AM | #6 | |
We couldn't get past a high 1.8 second until Matt from FSP showed me the 40MPH spin on the tires for a few seconds. It was an amazing difference with these tires.
02-26-2016, 08:50 AM | #7 | |
I've just seen sooooo many people roasting stock, all season street tires thinking they're a ProStock car and then wondering why they're still spinning. OP: If you're wanting to get the most out of these cars, you're going to need to get a set of rear wheels, preferably 17", and try these out... http://www.mickeythompsontires.com/s...item=ETStreetR They are, hands down, the best DOT approved DR I've ever run. The 305/45/R17 would help you grip like flypaper, even on a less than stellar track prep. |
02-26-2016, 03:39 PM | #8 | |
This is why i was asking for tips! Seems like i always see guys with regular street tires smoking the crap out of them. My AWD was simple- 5grand, dump the clutch and leapfrog off the line. Little bit more to it with this car to get off the line right! |
02-27-2016, 09:57 AM | #9 |
Drives: 2016 1SS Mosaic Black MRC NPP A8 Join Date: Feb 2016
Good stuff on this thread. I'm heading to the strip after a quick break in period to learn to put this power to the ground!
02-27-2016, 05:21 PM | #10 | |
Drives: Camaro 2SS A8 NPP Join Date: May 2015
Mosaic Black 2SS A8 NPP
12.08@115 MPH |
02-27-2016, 05:21 PM | #11 |
Has anyone tried nitto invos?
12.08@115 MPH |
03-05-2016, 07:25 PM | #12 | |
03-05-2016, 10:52 PM | #13 |
Those are a couple of pretty awesome and constant runs!!
03-05-2016, 11:37 PM | #14 | |
Drives: SS 6 speed of course Join Date: Jan 2016
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
