07-02-2014, 09:51 PM | #1 |
Drives: 14 Camaro 1LE,328i, and some Hondas Join Date: May 2014
Kooks 1 7/8" headers installed *vid*
http://youtu.be/NFV8MzO7ptY
Kooks Headers Camaro NPP exhaust: http://youtu.be/NFV8MzO7ptY My 1LE is a month old and installed my headers with cat deletes today. No tune(yet), no CEL. I did the old defouler trick. Works great. A few things I want to recommend: 1. Definitely make sure you have a second person handy when you go to reinstall the dipstick. 2. No need to remove the steering shaft. It's much easier to take off the two nuts holding the manifold and the cats together(only needed on driver side). Everything slides in and out without a hitch if you do. 3. Heat around the o2 sensor, and then use some ice or dry ice directly on it. It will spin out with no issues. If you do have trouble, try some pb blaster then repeat the heat and ice.
14' Camaro 1LE - Now self-tuned
FRH ported heads, Cam Motion LL solid roller, Jesel rockers, Morel lifters, Kooks headers, Corsa exhaust, ADM intake, Stock compression/bore/stroke 551whp 504wtq Last edited by 1sick_eg; 07-03-2014 at 06:07 AM. |
Thread Tools | |
