11-21-2017, 01:34 PM | #1 |
Drives: 2011 2SS Join Date: Jan 2014
Blown N/A E85
I've done a ton of research and still have questions and hoping maybe someone is already running this setup.
I have a stock bottom with Texas speed's LS3 231/246 .640/.615 112 LSA cam, PRC ported/polished/milled heads 11:1cp, 1-7/8 headers, no cats, full 3" exhaust and all supporting mods. I'm putting on an LSA blower, switching to full e-85 and leaving the N/A cam in the motor but want max safe reliable power. I'm hearing the zl1 pump is too small and need dual fore or squash for fuel. What I'm Askin is what is definitely needed for fuel, injector size, and pulley sizes, supporting mods?? And will I need an 8 rib setup? I'm hearing I won't be able to run high boost with that cam and 11:1cp. I'm not going turbo or changing cam or bottom end. Thoughts or suggestions much appreciated. |
11-21-2017, 02:21 PM | #2 |
Drives: 2014 1LE, 1996 z28 Join Date: May 2015
You will need a dual pump setup, ideally dual 430/465 pumps. Fore, squash, or agp all have nice dual setups. I would shoot for at minimum 850cc injectors, ideally 1000cc.
The compression ratio is a little high, but not that much more than stock. The large cam will help lower dynamic compression, and should in theory make it more tolerant of boost than say a stock cam.same powerbatva lower boost level basically. |
11-21-2017, 04:07 PM | #3 |
'It's an experiment'
I did DSX e85 Kit and aux pump on mine. Works great. I’ve since gone forged and the kit has had no issues keeping up.
I had a VVT SS1 N/A cam with my L99/LSA ported blower with this same kit and it too did fine with the DSX kit... -Don
747 RWHP 794 RWTQ
11-22-2017, 09:11 PM | #4 |
So you left the stock pump and installed a second aux pump with provided enough volume/pressure? This would save a lot of money over squash. I haven't heard of doing just the aux pump with stock or did you already have a zl1 pump?
11-22-2017, 09:51 PM | #5 |
I have a zl1 pump (which I upgraded from the SS pump) and Dave’s aux pump. Dave reprogrammed my FPCM (fuel pump control module) for free — part of his service.
So, dropped in the ZL1 pump and then installed the e85/aux fuel pump kit...have many data logs to show it’s working... Don’t forget, fuel injectors will be needed for e85, I have the ID1050x... -Don
747 RWHP 794 RWTQ
05-26-2021, 09:00 PM | #6 | |
Drives: 2011 camero ss Join Date: Dec 2018
Sent from my SM-G965U using Tapatalk |
05-26-2021, 09:01 PM | #7 |
05-26-2021, 09:05 PM | #8 | |
102mm nick williams. E85 aux pump and blown ZL1 pumps...not sure if the shop i was @ reprogrammed the fuel pump control module Sent from my SM-G965U using Tapatalk |
05-27-2021, 06:39 AM | #9 | |
Drives: 15 Camaro SS Join Date: Oct 2018
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-27-2021, 08:51 AM | #10 |
Drives: 2010 Camaro SS Join Date: May 2018
I think 11:1 is an ideal compression ratio for your setup provided you stay on E-85, with pump gas its a little on the high side. You could still run it but I would keep the boost conservative if you go that route (10psi or less on 93 imo)
Your going to make more power with less boost with a higher CR, so you don't have to work the blower as hard to make your desired power level provided you have enough octane to support it and with E-85 that's not going to be a problem. Just make sure you have the fuel sytem to support it. Dual or Triple pump, 1000cc injectors or bigger. Your fuel system is a good place to plan on more than you need because you will most likely grow into it. And yes do a 8 rib, you'll be glad you did. Good luck with your build, let us know how it goes. |
05-27-2021, 11:37 AM | #11 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Last of all dont forget the No Pucker passenger seat cover
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
05-30-2021, 02:01 PM | #12 |
Some of us still have the full "unstripped" version
