02-25-2024, 06:35 PM | #1 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
No speakers in package shelf?
2023 1SS, not-Bose... was playing with the equalizer and fader and realized the only sound in the rear is coming out of the sail panels (I think). There's virtually no bass. All the bass comes from the doors, so I assume the base system only has two lower-range woofers.
The package shelf looks like it has speaker grilles, but I haven't yet looked under it from the trunk side, if it's visible. Are there supposed to be speakers there? Is it possible to add speakers without cutting into any factory wiring? |
02-25-2024, 09:52 PM | #2 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
AFAIK only the Bose system (3LT, 2SS, ZL1) has speakers at those two locations.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
02-26-2024, 10:53 PM | #3 |
Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
I’m just going to put 2 cents in here - if you want better bass, in lieu of installing the rear 6x9s, I would encourage you to explore a removable powered sub for your trunk.
I have a JL 10” in my convertible trunk and it absolutly slays that last octave. Here’s a link to Crutchfield and I’m sure there’s some non-Bose sub installs here in the forum. I’m sure other brands are less expensive and sound very good. https://www.crutchfield.com/S-NEgeo1...ubwoofers.html The coolest things about bass are a) that it’s omnidirectional - you can’t tell where it’s coming from and the trunk is fine - and b) your ear is not sensitive to distortion so much - so you can use an ultra-efficient Class D amp and crank it to the limit. Here’s my install. https://www.camaro6.com/forums/showthread.php?t=561714 |
02-26-2024, 11:05 PM | #4 |
Oh, and this JL Stealthbox for Gen 6 Camaro looks pretty epic - although the price is a little epic at $1,500 too.
https://www.jlaudio.com/products/sb-...ealthbox-94632 |
02-27-2024, 10:19 AM | #5 |
Thanks...and nice install.
I did a bit more searching and found a few threads about adding speakers back there. Too much interior disassembly and mucking around for me. I was hoping, even if unrealistically, there would be unused connections back there and I could buy factory parts to put it together. That's not the case...lol. A powered sub, that might be an idea. I'm not looking for perfection, just a little extra. |
02-27-2024, 11:13 AM | #6 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
02-27-2024, 08:18 PM | #7 |
I think the Bose is easier because the amp is in the trunk. With the battery in the trunk too, this makes adding a sub more straightforward.
FWIW, a little info from Crutchfield’s Research Garage: https://www.crutchfield.com/learn/20...et-camaro.html |
02-28-2024, 12:50 PM | #8 | |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
Thanks for posting the Crutchfield Research Garage link. I haven't seen any other posts detailing the process for replacing speakers. Very helpful!
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
02-29-2024, 02:51 PM | #9 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
"When you’re done with this job . . . make sure the [rear] seatbelts are secured to stock specifications and working properly. We know you’re too good a person to subject normal-sized adults to long rides back here, but just in case…." |
