03-22-2010, 10:22 PM | #1 |
Drives: 2010 ZL550& 2021 C8 Z51 Join Date: Feb 2010
Changing from 3.8 to 3.6 question
If I change my pulley from the stock 3.8 to a 3.6 pulley do I need to have a new tune?
03-22-2010, 10:24 PM | #2 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
If your car is tuned now, yes it will need to be retuned for the additonal boost.
03-22-2010, 10:24 PM | #3 |
Drives: 2ss Join Date: Oct 2009
yes
03-22-2010, 11:38 PM | #4 |
The car came with the SCT X3. Should I use that to tune the car or should I use something else? Also does anybody know a good tuner,around the Philly/Delaware that can use this tuner?
03-23-2010, 08:43 AM | #5 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
race proven motorsports, claymont de. I'm not sure if fran can use the sct x3 tuner but give him a call
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
03-23-2010, 09:04 AM | #6 | |
If your running a Magnuson tune, there should be plenty of fuel already programmed in for the extra boost but it would be wise to add a Wide band O2 gauge to monitor it or have it checked on a local dyno Preferably in an O2 bung welded in the pipe before the cats, NO TAIL PIPE SENSORS PLEASE. If you need tuning assistance I tune with SCT Daily, via Email. Ted.
www.jannettyracing.com
Similar Threads | ||||
Changing rear end oil and trans oil? | caverman | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 10 | 03-01-2010 10:09 PM |
01 Z28: thinking about changing wheels - question | Chevyg1rl | 4th Generation Camaros | 11 | 02-25-2010 08:13 AM |
Question Involving 4.10 gears & Bushings | Deric884 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 02-13-2010 06:53 AM |
3.8 S/C in 91 FBird? | Rman91Bird | 3rd Generation Camaros | 18 | 04-15-2009 03:00 PM |
Exhaust question | ElManny | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 01-02-2009 09:41 PM |
