08-31-2019, 04:37 PM | #1 |
WHPLSH
Drives: 2010 SS Maggie,ARH,Meth,AFE Coilove Join Date: Mar 2010
Doing cradle bushings
So I got a set of Hendrix solid cradle bushings and his offset diff bushings and just ordered Z/28 upper control arm bushings, Are there any TTY bolts that need to be replaced when doing this? And it is probably best to drop the whole cradle right? can all 3 be done in 1 day with jack stands? thanks.
08-31-2019, 04:43 PM | #2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Technically the cradle bolts are TTY.
Any bolt that is "X ft-lbs + Y degrees" is going to need to be replaced.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
08-31-2019, 05:00 PM | #3 |
WHPLSH
Ok, better order those with the control arm bushings, Is it wise to do the upper control arm bushings while doing the cradle?
08-31-2019, 05:02 PM | #4 | |
Captain Gingerbeard
I did everything in one go--springs and struts and all.
08-31-2019, 05:27 PM | #5 | |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Edit: You don't have to drop the cradle completely to do the cradle bushings. Just lower it enough to use the socket and heat method. Easy.
More to come. |
08-31-2019, 11:36 PM | #6 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Make sure you have something to generate enough heat, I used a small propane torch and worked great only took a few minutes each. An helps to disconnect sway bar too.
Orange Krush II
09-01-2019, 04:49 AM | #7 |
WHPLSH
How about the offset diff bushings are those hard to remove the stock ones?
09-01-2019, 07:09 AM | #8 |
SomeguyK
The stocks can be a pain in the ass to remove. Do you have access to a press? That will make it much easier. If not, get a sawzaw and some good blades. Cut out the old bushing best a possible. Then carefully cut the metal sleeve. Try not to knick or cut the diff itself. Knock out the sleeve. If you do knick them, just smooth them out. Clock the offsets so the bolt hole is at the 6 o'clock position. Push in by hand, then grab a piece of wood and a hammer (unless you have a press). Tap them into place. Done. Can be done in car just lowering diff...but easier if removed.
More to come. |
09-01-2019, 11:17 AM | #9 |
There's a tool out there some where that presses them out, just look in the DIY section or here in the Suspension sub forums
Orange Krush II
09-01-2019, 07:52 PM | #10 |
WHPLSH
Thanks for the input guys, I think I am just going to do the cradle bushings now and the UCA and diff bushings at a later time. The diff bushing removal sounds like a PITA, I have the pegasus and Hendrix diff bushings just got them in the mail but the cradle will be the first job to tackle.
09-02-2019, 11:34 AM | #11 |
Drives: 2014 Camaro SS Join Date: Jan 2019
Half the stuff back there is TTY. I posted a thread recently from my research in which ones are TTY. I have all the part numbers saved on my hard drive.
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
