10-03-2017, 06:30 PM | #1 |
Drives: 2010 Camaro 2SS/RS Join Date: Oct 2016
Lifter swap? Or no? 2010 L99
I have 2010 SS w/ 72k miles... i've had it for a year
When I start it cold in the morning, or after it's sat for 5 or so hours, about half the time the lifters will be loud for 1 second. Loud enough to hear inside the car. I've only had it for a year so I don't know how long it's been doing this. Is this somewhere I can just keep using indefinitely, or should I tear apart the engine and do the lifters? My real concern is a lifter needle or whatever it is (that holds the roller on) slamming up and down before the pressure builds up , breaking and filling my oil pan with metal. General consensus i've seen is this is normal , especially if it's only a second or two, and won't be a problem in the long run. Also i've seen some people replace the cam as well, is this necessary? Or only if there is clear lobe damage? |
10-03-2017, 06:52 PM | #2 |
Are you stock?
10-03-2017, 07:02 PM | #3 |
10-03-2017, 07:17 PM | #4 |
Lifters should be fine, springs maybe a little tired thats all.
10-03-2017, 08:45 PM | #5 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
On the main page type in tic tic tic in the search window and scroll down to tick tick tick tick in the searched threads. That should enlighten you on where your at.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
10-03-2017, 08:48 PM | #6 |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
AFM lifters have been known to have issues stock. Sounds like an opportunity or good excuse to upgrade to LS3 lifters and a Cam : )
10-03-2017, 08:55 PM | #7 |
Drives: cars Join Date: May 2011
Hydraulic lifters leak down by their very nature of being hydraulic and take a couple seconds to build back oil pressure in them. Accept it because it's normal and replacing them like for like is a giant waste of money that won't change anything.
10-03-2017, 09:24 PM | #8 |
Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
My 2011 L99 did the same thing. They were replaced under warranty in 2014. Start ups are quiet now no matter how long it sits.
10-04-2017, 02:50 AM | #9 |
Drives: 2015 Camaro 2SS Join Date: Oct 2016
I did my own a few months back [ticking at 11k] bought new GM lifters, took the heads off and changed them all, no more ticking.
10-04-2017, 04:51 AM | #10 |
It’s a bit of work but not to hard. What I would do is change out the lifters to LS3/LS7 put a new LS3 cover on it to remove the DOD. But absolutely keep the VVT.
10-04-2017, 04:56 AM | #11 |
You'll be fine...at 72k? I wouldnt worry
10-04-2017, 07:52 AM | #12 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Ever see an LS motor that spins the lifter in the bucket....after tapping for a while....? Plan on a new motor.
Better to fix it before the major carnage. Lifters on an LS motor are a piece of cake. There are a bizzillion short cuts. I've even seen it done one side at a time leaving the intake manifold on. But, even doing it the right way, slowly and methodically is a piece of cake. On modern engines it's one of the easiest upper end job you can imagine. Even the intake gaskets are reusable. Would be the perfect time to do some LT headers, LS3 conversion, mild cam, new lifters, new oil pump, chain, dogbone... power up it a bit and bulletproof it. Driving it around with a lifter going bad is just waiting for it to crap it's pants one day. And when it tears up that lifter bore... say hello to a new $6000 engine and $$$$$ labor and downtime... If you don't want to mod it you could even throw in new L99 lifters for a couple hundred. Friend of mine just did it on a 5.3 truck without removing the intake for cost of lifters, buckets, headgaskets, exhaust gaskets, headbolts. Slid one head off at a time hanging that side of the intake up with a bungee from the hood. Rednecks find the most genius repair hacks. |
10-04-2017, 08:21 AM | #13 |
Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
old oil can accentuate the noise. do a good flush and oil\filter change. if it is near that time, needs to be done anyway. if it doesn't change anything, at least you have fresh oil!
10-04-2017, 10:27 AM | #14 | |
