Old 10-21-2021, 02:08 PM   #1
aaberg
aaberg's Avatar
Drives: 1997 30th conv & 2012 45th conv
Can not close trunk or learn windows
After restoring the blend door I have connected battery again. Now I get a message on display says "open then close driver window". I do so but message still on. I have repeted the process but after seven times the window remain in open and unable to proceed for a while. I have also hold the button for 5-10 seconds in both open and closed position. Even tried to clear with a obd scanner.
Also noticed that trunk lid is open and can not be closed. Then pushing trunk opening on drivers door nothing sounds/happens same with fob. .
It's a Camaro 2012 SS convertible and top is down (can't close top due to trunk open).
Any ideas how to solve this two issues?
aaberg is offline   Reply With Quote
Old 10-21-2021, 04:41 PM   #2
L6611983
Drives: 2010 Camaro 2SS
I am having the same problem with the DIC roll windows up and down it doesn't go away after I restart the car it shows up again
L6611983 is offline   Reply With Quote
Old 10-21-2021, 07:04 PM   #3
Richard Cote
Drives: 87 Corvette & 2010 SS Camaro
try disconnecting the battery leads . I have taken mine off an touch them together so I know it drains any out of the car then reconnect .
Richard Cote is offline   Reply With Quote
Old 10-22-2021, 02:19 AM   #4
L6611983
Roll window down hold for 10 sec up again 10 sec then alternate for passenger side repeat 3 times then it disappears for good , start the engine and roll windows up and down once more that worked for me
Old 10-22-2021, 04:36 AM   #5
aaberg
aaberg's Avatar
Lightbulb
UPDATE and SOLUTION:
After one night with battery charger I tried to lock trunk and it worked at first time!
But the button on driver door for trunk opening didn't work and windows relearn didn't work. BUT after closed and secured the top (that was possible to do once the trunk was locked) I tried again to relearn windows and it worked at once!
After relearned windows the trunk button on drivers door worked as well!
So the solution to relearn windows on convertibles seems to be that you have to have top up and secured. I guess the problem with locking trunk had with low battery, even if i think it was not that drained. Also seems like you have to relearn windows before trunk button work.
Old 10-22-2021, 08:38 PM   #6
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
good to know for us vert peoples...Ill keep this one in the back of my mind.
Retired MSgt USAF
MSgt O is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
