Old 06-18-2014, 02:11 PM   #1
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Manual transmisson 5th gear issue...now with video
updated with video
When I'm driving in 5th gear, lets say 40mph the shifter shakes and rattles, almost feels like a bad syncro or something.
This only occurs in 5th gear.
Car is at the dealer and of course they are telling me its normal.
Anyone else have this issue or is it normal?
My 2010 did not have this issue.
-Bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 06-18-2014, 02:47 PM   #2
gm_joe
Drives: 2002 Pontiac GP 40th GTP, 2012 ZL-1
5th gear, 40mph seems a bit too slow. The owners manual specifically says not to let the engine begin to lug in any gear. I think you just need to keep the rpm's up a little. I usually try to stay above 1500 to 1800 rpm when cruising.
gm_joe is offline   Reply With Quote
Old 06-18-2014, 03:12 PM   #3
HDRDTD
-Bobby
And I'll bet it's do it at 40mph in 6th gear as well.
At 40mph, you should be able to be in 5th and accelerate, but to cruise at 40 in 5th is lugging the engine a bit. Drop it to 4th.
Old 06-18-2014, 03:19 PM   #4
Drumminxx
Drumminxx's Avatar
Drives: 2014 2SS RS 1LE
I can feel some vibration in the shifter but not so much that it concerns me and I can cruise in 5th at 40 with no problem. My issue is trying to navigate a parking lot in 1st without it lugging but our cars are geared different in the rear....
Sent from my SM-G900V using Tapatalk
Nice car bro!
Drumminxx is offline   Reply With Quote
Old 06-18-2014, 03:49 PM   #5
Emvici
Drives: 2014 ZL1 White Convertible
I drive with my car in 5th & 6th 42 - 45 mph and just simply coasting down a street with absolutely no issues, I have been doing it since day 1. The engine is probably at about 1300 rpms and it does not lug it at all. Of course I am not on the gas much if any, I could, but don't accelerate from either of those gears, I simple coast along getting 17 mpg on some open urban streets.
Emvici is offline   Reply With Quote
Old 06-18-2014, 04:18 PM   #6
Coupe
Coupe's Avatar
Drives: 2014 ZL1
I have used 5th gear at 40 mph with no issues. Basically, repeat what Emvici said above.
Coupe
2014 Camaro ZL1, Red Hot, M6, Bright Aluminum Wheels.
Coupe is offline   Reply With Quote
Old 06-18-2014, 04:21 PM   #7
deahl001
deahl001's Avatar
Drives: 2013 Chevrolet Camaro ZL1 CRT M6
I regularly use 5th gear from 40-50 mph with no issues... That being said, 40 is basically the bottom end of 5th.
2013 Camaro ZL1 - CRT M6 ECF
deahl001 is offline   Reply With Quote
Old 06-18-2014, 04:29 PM   #8
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
If you are using more than 20% or so throttle in 5th gear going 40mph you will experience lugging. There's probably nothing wrong with your car.
CamaroTom is offline   Reply With Quote
Old 06-18-2014, 04:49 PM   #9
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
That's just it, To get out of the rattle I put it into 6th and no issues.
Understand, its not a lugging shake rattle, its more like a syncro rattle.
-bobby
Old 06-18-2014, 06:51 PM   #10
DarthZL1
DarthZL1's Avatar
Drives: 2014 ZL1 M6
What he said. Go to 4th, shift up when you get to 50, see if it's still happening.
Sent from my SCH-I545 using Tapatalk
--- DarthZL1 - 2014 ZL1 #2095 M6 Black. Bone Stock ---
--- BigNLo - 1996 Impala SS Hot Rod Black. Lots of mods ---
DarthZL1 is offline   Reply With Quote
Old 06-19-2014, 05:07 PM   #11
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
After getting tired of the dealer techs telling me its "Normal" I went there today and insisted that someone else higher in the food chain drive the car. They had the shop foreman drive the car with me and FINALLY he agrees with me. They still have the car and he told me he would call engineering tomorrow and be guided by what they say.
-Bobby
Old 06-19-2014, 05:59 PM   #12
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
-Bobby
Sounds like you are getting it worked out but I was going to say I didn't think it was normal. Don't know how many ZL1's you dealer has but I would say make them drive another new car and show him the trans is not shaking in 5th. Good luck.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 06-19-2014, 07:34 PM   #13
ZL12013
ZL12013's Avatar
Drives: 2013 ZL1 & 2005 F150
My car doesn't see 5th unless I'm on the highway, I usually don't get in 6th unless I'm going over 60. When doing a quarter mile I usually don't get to 4th until I hit the finish, these cars are made to be driven slightly aggressive.
ZL12013 is offline   Reply With Quote
Old 06-20-2014, 11:47 AM   #14
CJ1034
CJ1034's Avatar
Drives: 2012 ZL1 IOM Manual
5th gear is for shifting from 155 mph to let the engine have a break!
5th at 40, must be trying to save gas, buy an econobox.
CJ1034 is offline   Reply With Quote
