10-10-2009, 12:05 PM | #1 |
Drives: 10 SIM 2SS/RS LS3 Join Date: May 2008
New "LS3" badges on the hood!
Just put these mirror stainless steel "LS3" badges on both sides of the hood bulge that I got from emblempros.com. They look real good on it, almost like factory.
If you're putting these on, make sure it's fairly warm outside or use a hair dryer to heat up the 3M adhesive and also make sure that the adhesive is centered along the back of the emblem so that it doesn't show around the edges once you get it on. I used a razor or dremel tool to trim the edges before since there was a little excess. You'll probably need a razor to initially get a corner peeling off of the adhesive since the red backing is not easy to remove otherwise. Also need to have it positioned exactly where you want it because once these go on, they're not coming off! I just used a ruler and lined it up along the top angle of each side of the hood bulge and measured a set amount back from the edge of the bulge near the windshield, spaced each letter out 1/8"
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... Last edited by topgun1; 10-10-2009 at 09:22 PM. |
10-10-2009, 01:26 PM | #2 |
Drives: BLACK ON BLACK 2012 CAMARO SS Join Date: Feb 2008
NICE!
BLACK CAR + FLAT BLACK STRIPES + BLACK WHEELS = BLK PW3R!!
****Thanks to Silver Streak for the pic I used to make this sig**** |
10-10-2009, 04:46 PM | #3 |
#8504
I like it a lot. How do you think they would look on a car with the hood stripes? I'd really like to try something like this with my car, but I've got the cyber gray hood stripes and am not too sure how the final product will come out.
Nice job
2016 Camaro 2SS Hyper Blue, A8, NPP
Past: 2010 Camaro 2SS/RS M6, Silver Ice Metallic w/ Cyber Gray Rally Stripe package, Inferno Orange interior, factory "perma-grin" VIN: 2G1FT1EW1A9108504 Delivered 7.7.09 |
10-10-2009, 06:11 PM | #4 |
I think they would set off the stripes, the mirror finish with the cyber gray background, would definitely stand out more. I originally had the cyber gray stripes ordered, but decided for the clean lines. go for it!
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... |
10-10-2009, 06:39 PM | #5 |
FBDY or no Body
Drives: 2010 CGM ZL1 clone/13 Silverado HD Join Date: Mar 2009
I bought them too. They are quality peices. The only problem I have when I got them was the rough edges. You could see where the cutter started and ended. I took my dremel and smoothed all the edges. It will prevent the dry cloth or wax towel from catching on them.
"Camaro Mike" of NY
CGM/M6/ZL1clone/GFX/Hurst/SLP/K&N/BMR/Niche Happily cruizin 7/31/09 |
10-10-2009, 06:44 PM | #6 |
How U Doin?
Those look nice. Where did you guys get them and do they have ones for L99?
10-10-2009, 07:14 PM | #7 | |
Drives: 2010 2SSRS Inferno Orange LS3 Join Date: Aug 2009
10-10-2009, 07:25 PM | #8 |
Drives: '10 Camaro SS Join Date: Apr 2009
Looks good! Do they match the word Camaro and SS on the side too?
2010, SIM, 2SS/RS, LS3, CGM Stripes
10-10-2009, 09:16 PM | #9 |
emblempros.com and yes, have them for the L99 as well as other emblems
10-10-2009, 09:17 PM | #10 | |
pretty close, not as thick though.
10-10-2009, 09:18 PM | #11 | |
this is not good--was it hand washing?
10-12-2009, 10:05 PM | #12 |
FBDY or no Body
What? Do you have the same ones from emblempros? The ones I have are stainless steel and wouldn't break if they get caught with a rag. You must have plastic emblems.
"Camaro Mike" of NY
11-01-2009, 12:47 PM | #13 |
Yes, they were the black plastic ones. Stay away from them! The SS ones are apparently much better
2010 2SSRS Inferno Orange Metallic
It's stock, I swear! |
Similar Threads | ||||
7282 gets her custom "LS3" hood cowl stripes 6-3-09 | Airforce1 | Camaro Photos | Spyshots | Video | Media Gallery | 115 | 02-15-2013 01:13 AM |
1968 Nickey Camaro hood??? | 1968 Nickey | 1st & 2nd Generation Camaros | 6 | 03-19-2010 12:05 AM |
* Groupbuy * ram air induction hood | REVOLUTIONSS | V8 Bolt-Ons & Tunes | 114 | 01-30-2010 08:40 PM |
Anyone in California Want a Carbon Fiber hood in Trade for there OEM Hood | henri26900 | USA - California | 7 | 09-24-2009 12:19 PM |
