03-09-2019, 12:49 PM | #1 |
Drives: 2014 Camaro ZL1 Red Hot Red Join Date: Oct 2016
No lift shift
Does no lift shift still work with all the nanny’s shut off?
03-09-2019, 01:38 PM | #2 |
Drives: 2010 ss Join Date: Oct 2015
would not do it with high hp levels...js unless u want to replace yr tranny alot
03-09-2019, 02:20 PM | #3 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
It’s active all the time..
- The NLS algorithm is controlled in BCM - Must be at or near WOT - 95% or greater TPS - Shift must occur in .50 seconds or less (clutch engaged, shift gear and clutch disengaged) - Must shift above a certain rpm 5000-5500 min rpm. I think it's 5000 rpms based on datalogging. - The rpms will jump up during the shift (how much depends how close you shift to the rev limiter) and held at redline. The quicker the shift; the less chance it will jump up. - The fuel/spark rev limiter (i.e. cut off) will not be activated at redline. - If done properly; the supercharger will stay in full boost, PE (Power Enrichment -commanded WOT AFR) will be maintained as well as full WOT spark timing throughout the shift. |
03-09-2019, 04:33 PM | #4 |
Thanks, wanted to ask before I let it rip at the tracks with slicks and all nanny’s off.
03-09-2019, 08:53 PM | #5 |
you must have been talking about a 2 step,sorry
03-10-2019, 11:34 AM | #6 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
In my experience, I'm pretty sure a few NLS runs is what killed my stock clutch, FWIW.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
