07-24-2019, 08:52 AM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Procharger 12 rib setup questions
So I am wanting to turn my F1A up, currently running a 3.85 12 rib pulley to feed my ERL 427 in my camaro, I want to drop down to a 3.55 pulley will this cause belt slip issues? Also does anyone know anyone who makes larger than a 7.65 12 rib crank pulley compatible with our cars / or the ATI dampener that I had to use to utilize the Procharger pulley?
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
07-24-2019, 11:40 PM | #2 |
Thats the biggest crank pulley they make in a 12 rib. You should be fine belt slip wise with a smaller blower pulley. The F1s are geared better internally.
07-25-2019, 01:15 PM | #3 |
Thanks!
07-26-2019, 08:55 PM | #4 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
I tried to get some people to go in on making them
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
07-31-2019, 04:05 PM | #5 |
Drives: it changes Join Date: Nov 2010
ASP can make any pulley size/type you want really.
