07-25-2014, 10:41 AM | #1 |
Drives: 2010 IOM 2SS/RS Join Date: Oct 2008
Safe, cost-effective way to raise your car for fluid changes?
I'm in a dilemma of cost vs. safety vs. ease of changing oil/transmission/diff fluid.
I just bought brand new Craftsman jackstands, and had an old hydraulic floor jack that doesn't lift the car enough to get the stands underneath it . I'm starting to re-think that whole thing because I'm not even sure I trust a few inch thick bars holding up the front end of a 4000 lb car. I recently looked into these: http://www.raceramps.com/car-service-ramps.aspx I figured ramps are safer because it doesn't seem like it'd collapse on you. It might destroy itself at the point you drive on it. I'd need the 67" 2-piece if I want to at least do an oil change and transmission/diff fluid change since the transmission is further center and I need more height. DAMN these are expensive. There's gotta be another way. Any thoughts? |
07-25-2014, 12:17 PM | #2 |
Race ramps are very nice but are also very very expensive! If you could handle the cost the 10" high ones would be great for that!
I got a set of Rhino Ramps at autozone for $55.00. Just measured them. They are 6 1/2 inches high. I change my own fluids with those. They work fine for that. |
07-25-2014, 11:33 PM | #3 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
Rhino ramps here also. Working on the exhaust:
07-25-2014, 11:41 PM | #4 |
I still set a couple jack stands just in case, it makes me feel better, no squishy squishy!
07-25-2014, 11:44 PM | #5 |
Drives: 2012 Camaro 2SS/RS Victory Red Join Date: Jun 2014
Just dig a pit and drive over it. Cheap and free exercise.
07-26-2014, 05:41 PM | #6 |
Drives: bicycle Join Date: Jun 2014
07-28-2014, 10:01 AM | #7 |
If you check out the Amazon page for Rhino ramps, there are two pictures of ramps that failed and it's not pretty:
http://www.amazon.com/gp/customer-me...g_see_all_img0 No space for a pit on my end, I have a concrete garage floor. I've seen some with pits though. |
07-29-2014, 02:00 PM | #8 |
Drives: 2014 Camaro 2LT/RS BRM Join Date: Feb 2014
I used something like the Rhino Ramps (different brand) that I used for my 2004 GMC Canyon. They worked fine for the four years I used them. Got them at Pep Boys for $60 at the time. I still them and plan to use them for my Camaro after my 2 yrs of free oil changes is up.
07-29-2014, 03:40 PM | #9 | |
I have the larger Rhinos. They do work perfectly fine and I believe there is no chance of failing with my Camaro! |
07-29-2014, 04:26 PM | #10 |
Good catch.
Is there enough clearance under these to get to where the transmission drain/fill holes are? |
07-29-2014, 04:32 PM | #11 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
I bought 2 pressure treated ten foot 2x12's and cut a 4,3,2,1 foot section from each and screwed them together in that sequence. It's super stable and gives 6 inches of lift.you can screw a 2x2 across the end on the top section to keep from driving off the ramp.Works great and is safe.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
07-29-2014, 05:28 PM | #12 |
07-29-2014, 08:39 PM | #13 | |
07-31-2014, 08:42 PM | #14 |
Decision: went with race ramps. Why? I found a good deal and I also liked the amount of clearance I get + being able to disassemble it. I understand that Rhino ramps when misused will break, but I just don't feel safe after seeing that. I don't feel horrible about paying full price for race ramps after this:
http://www.camaro5.com/forums/showthread.php?t=332767 Thank you, kkhammer1 (4th post down) for pointing out the coupon code for autoanything. Not only do I get 16% off, race ramps also have a $20 rebate on their site. This doesn't make the deal so bad. I couldn't find the offer for the free wheel chocks mentioned, though. I think that's gone. |
