12-22-2019, 05:59 PM | #1 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Is My Oil Pan Leaking?
So I'm trying to prep for hopefully my upcoming can install of I can decide on what to get and gather up everything I need. I'm not planning on pulling the motor since I don't have the tools it the resources, I could also see a bunch of PITAs occurring and a lot of broken things by pulling the whole motor out. However it might look like I will need to.
I pulled off the air deflectors, and what GM calls the "shear plate" I'm not sure why it's called that unless it is structural and is part of crash resistance but anyway I had noticed a drop off oil collecting at the bottom of the oil pan. So I figured this would be a good time to look up in there. If you look at the last picture that is looking straight up at the bolt on the oil pan you can see oil is pooled up around it, I feel like the leak is definitely coming from the pan. Since you are technically supposed to pull the motor to do a can swap it would be a good time to fix it, however does anyone think it could be coming from somewhere else? I don't know why GM had to switch to rtv instead of gaskets everywhere in the LT1 especially when it appears things leak more. I'm hoping it's not a rear main seal it something like that since that would make me think crank bearing it something like that is wearing out. I guess the first thing I should do is ensure the oil pan bolts are properly torqued? Since maybe somehow it got missed at the factory, which I highly doubt with today's quality control, I could then clean it up and see if it still leaks. Last edited by cmitchell17; 12-22-2019 at 06:15 PM. |
12-22-2019, 06:24 PM | #2 |
Drives: 2017 1ss 1le Join Date: Sep 2015
yes my money is on your pan bolts being loose
12-22-2019, 09:01 PM | #3 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
I've read multiple times on the forum that pan bolts not being torqued from factory correctly. Tighten them up, clean it up and check again in a week.
12-22-2019, 09:07 PM | #4 | |
I got my torque wrench and torqued them to 25 Nm for the 13mm and 12 Nm for the 10mm according to the sequence in the service manual as best I could. A few of them I had to use a gear wrench to tighten and not the torque wrench since I couldnt get it in there. |
04-06-2020, 04:28 PM | #5 |
Drives: 2017 Camaro 2SS Join Date: Mar 2019
Ugh, looks like I might have to put mine on the quickjacks this weekend, the wife noticed a couple of oil drops on the floor of the garage. My oil pan had the same thing, not quite ready to drip yet. Any chance of the dipstick tube being a culprit?
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon |
04-06-2020, 06:40 PM | #6 | |
04-06-2020, 07:19 PM | #7 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
I noticed the same thing a while back during a oil change and some of the oil pan bolts were loose. I torqued them to the proper spec and 5000 miles later when I did another oil change there was no leaks.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
04-06-2020, 10:08 PM | #8 | |
Thanks for the torque chart! It'll help pass another weekend of social distancing, who the hell is going to get under the car to bug me? I have a couple of torque wrench options, so I have officially run out of excuses
Gary
04-07-2020, 10:27 PM | #9 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
I had the same problem one day before my warranty expired. I took it to the dealer and they say they "replaced" the gasket. In any case it doesn't leak now. I think it was just a matter of loose bolts, but since I had warranty...why not have the dealer deal with it!
Seems like GM missed tightening a few cars here!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
04-08-2020, 02:02 PM | #10 |
Drives: SS 6 speed of course Join Date: Jan 2016
I like the BMR engine mounts if you intend to work on the car, that said RR of the oil pan does make the cam install a bit easier. It takes 1.5 hours start to finish. Remember BMR mounts at the same time...
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
04-09-2020, 11:43 AM | #11 |
Banned
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Is there a TSB for lose bolts? If so dealer should tighten at no charge.
05-02-2020, 06:50 PM | #12 |
Drives: 2016 Mosaic Black Metallic 2SS Join Date: Jan 2019
Do you guys know how to get the metal sub frame cover piece off to access the oil pan bolts? I can't find anything about it. I think my oil pan bolts are loose too, got an oil leak.
05-03-2020, 05:36 PM | #13 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
They had to reseal or replace my oil pan gasket due to oil leaks right around 35000 miles on my 17. Also replaced my oil cooler due to leaks a little earlier than that.
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
05-03-2020, 05:56 PM | #14 |
Drives: 2018 1SS M6 Join Date: Feb 2018
there are i think 6 bolts maybe 8 that hold it on. then you have to drop the rear of it down first then it will pull out. the front of it is "scooped" around something to help prevent it from moving around i guess even though its bolted in.
2018 1SS M6 - OTR intake, HI Ram intake, Ceramic Coated TSP Headers Catless, AWE Touring Axle-Back, Flex Fuel, Pray Performace stage 3 cam, TSP ported heads, Pray Ported 95MM TB and Ported HI-RAM. SJM Line-Lock. F14 Drag Pack 17's with front skinnies. Tuned by Pray Performance.
