12-28-2018, 11:59 AM | #1 |
p2068 Fuel level Sensor B Circuit
Got in my car the other day and I looked down and saw that my fuel gauge was on E. I knew I had about half a tank and thought... DAMN IT!
I drove about 10 miles and it started working then turned off again. Now, every time that I turn off the car it doesn't work. But, I can get it to work when I give the car some gas and have a little fun. I was originally thinking is was the float in the tank sticking but I am beginning to think that it is the sensor going bad. Has anyone else had this problem? Any fixes that don't require dropping the gas tank?
764RWHP on e85 683RWHP on 91. M6 Black on Black on Black. 1300ID's, DSX Aux Pump and Flex Fuel Sensor, Lingenfelter 2.5 upper 9.5 lower, 100MM idler, AFCO HX w/ FANS. 1 7/8"ARH exhaust to axle incl LTH, MF's, Fuel Lab FF, Lingenfelter ported snout and TB, Lingenfelter CAI, RotoFab coolant tank, NGK 2 steps colder spark plugs, Moroso catch can, BTR Stage III cam, crank case breather. Tuned by Power Labs in Idaho Falls, ID.
01-02-2019, 07:41 AM | #2 |
An update on this...
I filled it up now that gauge is reading 3/4 a tank. But has not gone above or below that. I haven't driven it much so I think that it has more than that 3/4 tank. Any info helps on this.
