Old 02-28-2018, 01:22 PM   #1
le'1le
Drives: Future 1LE
1LE for FS Autox - Diff Oil
Hey guys,
I have been searching the forum like crazy looking for a solid answer on this and havent really been able to find one, so here goes.
1) What is the 1LE differential? Is it the same one as the ZL1 or the Z28?
2) Which differential oil have other 1LE owners here used for their car? Did you put in a friction modifier or not?
I currently eyeing either Redline 75w-90NS (https://www.amazon.com/Red-Line-Limi...=redline+75w90) or the Royal Purple 75w-90.
Also, some input on trans oil would help, seems like the two favorites here are Redline D4 ATF or RP.
Thanks everyone and happy to be here.
le'1le is offline   Reply With Quote
Old 02-28-2018, 03:40 PM   #2
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
Differential is the same as the SS, the gearing is different, 3:91 is what comes with the 1LE.
I use what’s in the manual,Name:  053AF722-C087-4D5B-91FE-2C8750C1ECD7.jpg
CreeperRS is offline   Reply With Quote
Old 02-28-2018, 06:55 PM   #3
3rdGenAg2010
Drives: 2014 Camaro 1LE
Originally Posted by le'1le View Post
Hey guys,
I bought my 1LE second hand and changed all of the fluids myself to set up for autocross. When I did the diff I used the oem fluid that comes with the friction modifiers already in it after reading about a bunch of people having issues with different fluids. Works great for me. Part number: 88862624. Redline D4 in the transmission is also what I run.
3rdGenAg2010 is offline   Reply With Quote
Old 02-28-2018, 06:57 PM   #4
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
RP all the way...tho Mobile 1 LS is just fine too, in the diff that is.
Old 02-28-2018, 07:26 PM   #5
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
You can use Amsoil with the weight stated in all Camaros except the ZL1.
its a syn is offline   Reply With Quote
Old 02-28-2018, 08:39 PM   #6
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I used the royal purple...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 03-02-2018, 07:44 AM   #7
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
RP here, handles track days well so far. No noise, no known issues.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 03-02-2018, 12:26 PM   #8
Hilflos
Drives: 2015 1SS / RS NPP
Swapped my stock SS diff with 3.91's on an Eaton True Trac, went with RP here also.
Zero complaints, zero issues.
Hilflos is offline   Reply With Quote
Old 03-02-2018, 01:14 PM   #9
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
REDLINE CAN NOT BE BEAT
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-07-2018, 11:43 AM   #10
le'1le
Drives: Future 1LE
I ended up going with Redline D4 ATF for the trans and AC Delco oil and additive for the diff. I figured since the car is still under warranty, i would rather run the prescribed fluid and not risk getting denied a warranty claim in case something goes wrong.
Thanks everyone for the input and clarification.
