Rick@Livernois
Old 05-17-2015, 07:00 PM   #1
tanur420
Drives: 2011 Camaro SS
CEL light issues
Ill start with the car, 2011 ss l99. Lt headers, no cats, ported tb, injen cai, rx catch can, 1le breather kit, and an underdrive pulley.
All of which was installed roughly 2 years ago. Also got it tuned right after the headers for the 02 sensors.
About 6 months ago I started getting random CEL that would come and go. Everytime I got them scanned was the same codes. It seemed to coincide with getting gas. Fill up, goes away. Get low, comes on. So I got a gas cap figuring maybe mine was shot. No dice still get it. The codes its throwing are to do with catalytic system efficiency below thresholds on both banks.
Anyways these are the codes. Any help would be hugely appreciated.
P2270
P0430
P0420
P2270
tanur420 is offline   Reply With Quote
Old 05-17-2015, 07:43 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Those are post cat sensors, Should have been set to "No error reported" when you had it tuned.
P0420 & P0430 Bank 1 and 2 lean
P2270 is bank 1 sensor 2 stuck lean
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-17-2015, 09:30 PM   #3
tanur420
The headers and tune was on for over 2 years before it started. Is there a way that the o2s could have gotten turned back on?
Old 05-17-2015, 09:32 PM   #4
1KillerSS
1KillerSS's Avatar
I know that is a long time, but none the less, after a tune you should never see those codes. Unless you took your car into a dealer or someone capable of flashing your PCM back to stock signal, no, they will not turn back on.
Build thread
Old 05-17-2015, 09:42 PM   #5
tanur420
Could the sensor itself be fried? Is there a way to test them?
Old 05-17-2015, 09:49 PM   #6
1KillerSS
1KillerSS's Avatar
Yea for sure it could be a bad sensor, but your throwing codes for both banks, so I doubt it. Normally I would tell you to swap the sensors from bank 1 to bank 2 but since both banks are coding, well then.....
Build thread
Old 05-18-2015, 06:02 AM   #7
tanur420
Guess ill call up my tuner and have him take a look. But all of those are codes that should be disabled?
Old 05-18-2015, 06:25 AM   #8
1KillerSS
1KillerSS's Avatar
Of the three that you fave, all three are post cat O2 sensors codes. After a tune, any post cat O2 sensors should be disabled, that is if you have headers.
Build thread
Old 07-03-2015, 10:42 AM   #9
chuckstacamaro
chuckstacamaro's Avatar
Drives: 2014 2SS/RS BRM Purchase 03/19/2014
Back in February I had Kooks LT Headers, Hi flow cats, X pipe and Kooks Off road mufflers installed. A CEL came on and stayed on which I expected because of the O2 sensors being overloaded by the new exhaust setup. Now (five months later) without doing anything else to the car. The CEL has turned itself off. Can the ECU make adjustments because the O2 overload is now the Norm for the car? Has this happened to anyone else?
chuckstacamaro is offline   Reply With Quote
Old 07-03-2015, 11:09 AM   #10
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
It'll comeback
hunter1660 is offline   Reply With Quote
Old 07-03-2015, 11:20 AM   #11
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Need to give us the code next time it happens. If it's the o2 sensors, it will be back. The hi-flows you have might have characteristics that met the ecu's parameters to remove the code(s) temporarily, but they'll be back eventually assuming it is o2 related.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 07-03-2015, 12:51 PM   #12
chuckstacamaro
Codes are O2 related.......I'll have to run a diagnostics later today to be sure.
Old 07-03-2015, 01:36 PM   #13
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
You need to be sure its not sen1 (upstream) related as that's where your AFR readings are Coming from. rear or downstream 02 sensors are okay to remove for headers they are just for smog.
OP, I would still go check things out you can test your 02 sensors there is a way to do it.
revived is offline   Reply With Quote
Old 07-03-2015, 01:59 PM   #14
chuckstacamaro
I know the O2 sensors are giving the faulty codes, I was more curious as to why the CEL light went OFF, it was On for the longest time after header install. Now its Off. I was wondering if the ECU corrected itself or recognized that the car now has a different reading because of the change in exhaust flow? The CEL is NO longer lite up.
