05-12-2021, 07:03 PM | #1 |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2017
Tires! I need help
I am stuck on what tires I want. I'm trying to stay around $1k for all 4 tires. i have narrowed it down to these. I take my car to the track not very often, Try not to drive it in the rain.
Continental Extreme Contact DWS 06 - $1024.96 275/40ZR20 315/35ZR20 Continental Extreme Contact DWS 06 Plus - $1045.14 275/40ZR20 315/35ZR20 BFGoodrich G-Force Comp-2 A/S Plus - $903.96 275/40ZR20 305/35ZR20 Toyo Proxes ST III - $794.5 275/40ZR20 315/35ZR20
TSP Stage 2 L99VVT-2.2 Camshaft 227/239, .629/.629, 113 LSA, Circle D Converter 3000-3200 PRC 260cc, Cylinder Head (Ported for the camshaft)
TSP.660" Dual Spring Kit w/ PAC Dual Springs & Titanium Retainers, 2.165"/1.59" Stainless Valves w/ Hollow Stem Intake, Comp Phase Limiter, 7.5" Push Length Rod, New GM VVT Camshaft Bolts, D.O.D Delete Kit, Ported Intake Manifold, Kooks High Flow Catted-Long Tube Headers, Flowmaster Outlaw Cat-back Exhausts Cold Air Inductions Cold Air Intake, 95MM Throttle Body Tuned on 91 Octane Gas |
05-12-2021, 07:59 PM | #2 |
Drives: 2013 1SS LS3 Join Date: Feb 2014
I just got the Continental DWS 06 Plus tires installed. A few hundred miles on them so far and very pleased. They balanced out perfectly and handling and traction seems great. They also weigh a bit less than the others so you'll be losing some unsprung weight too.
05-12-2021, 08:09 PM | #3 |
Thanks for the input much appreciated
05-12-2021, 08:16 PM | #4 |
Drives: 2014 Camaro RRM 2SS RS, M6 LS3 Vert Join Date: Aug 2015
When I had to replace the P-Zeros on my previous Camaro - a 2014 2LT RS coupe, I went with the BFGoodrich G-Force Comp-2 A/S Plus and liked them a lot. My current 2SS still has the original P-Zeros, and I will research tires when I get ready, but the BFG Comp-2s will have the inside track.
Good luck with your decision.
Dream it - drive it!
05-12-2021, 08:20 PM | #5 | |
05-12-2021, 09:45 PM | #6 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
If you’re not driving it in the rain why do you need all season tires? They will never grip like a summer compound, just stay above 40 degrees Fahrenheit. I just put on Nitto NT 555 G2 after running Nitto Invos previously and I’m the same sizes as you. Stick like glue and are in that $1k-$1.1k range.
05-12-2021, 10:28 PM | #7 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
I have the BFGs, like them alot
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
05-13-2021, 12:03 AM | #8 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I have the BFG's also. I think they are a pretty good tire. Plus if you get the Y rated they are a 186 mph tire.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 Last edited by morepowerjoe; 05-13-2021 at 12:15 AM. |
05-13-2021, 04:07 AM | #9 | |
05-13-2021, 05:36 AM | #10 |
I can see if you get cold temps and it’s your only car. With your mods you’ll overpower an all season tire but if you have to have that option I’d go with the Continental 06 Plus but they all are probably right around the same.
05-13-2021, 06:08 AM | #11 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I have the General G Max a/s 3's awesome grip. Great all weather tire.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
05-13-2021, 06:53 AM | #12 | |
Drives: 2015 2SS Commemorative Edition Join Date: Mar 2020
05-13-2021, 07:10 AM | #13 |
Drives: 2014 camaro SS Join Date: Jan 2019
the reason I switched from the P Zeros is because here in the northern part of the country when it gets cold, it is like driving on skates. add a little rain and you might as well stay home. turns out BFG was the ONLY company to make all weather tires in 305/35 size, so this is what I had to go with. VERY happy with the traction and performance in all weather conditions except snow.
05-13-2021, 07:26 AM | #14 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Flip a coin.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
