04-01-2020, 02:11 PM | #1 |
Drives: NFG Chevy Camaro 2SS Join Date: Jan 2020
Magnaflow catback replacement
Hey everyone, any help would be appreciated with the following.
I have a magnaflow comp series catback on my 16 2ss camaro without NPP. The drone is too bad for my likings. I have heard great things about MBRP. Can I remove axleback portion of mf exhausts and replace with MBRP? Both use 3inch pipes. Would this solve my drone problem? TIA |
04-01-2020, 02:24 PM | #2 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Yes, it may require a bit of fitting after the fact, but most of these exhausts are cut and hanged in about the same location. I can't comment on the drone.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
04-01-2020, 04:33 PM | #3 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Can’t comment on MBRP, but I switched from Magnaflow to AWE Touring and it’s amazing. Zero drone. No brainer move.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
04-01-2020, 04:47 PM | #4 |
Drives: 2018 camaro ss Join Date: Aug 2013
Just buy the borla resonator problem solved and is much cheaper
2019 charger scatpack FBO 11.16@122
2020 CAMARO LT1 6spd 11.02@ 135 dragy approved |
04-01-2020, 08:56 PM | #5 |
Thanks everyone. I’m looking at installing J-pipes tomorrow. If that doesn’t work I’ll look into the other options
04-03-2020, 09:47 AM | #6 |
J-pipes will get the job done. Probably be easier then welding in another axleback.
Tags |
exhaust, magnaflow, mbrp |
Thread Tools | |
