Old 09-09-2013, 06:59 PM   #1
BluePhoenix
BluePhoenix's Avatar
Drives: GMC Sierra AT4
Non-RS headlamp bulbs
What are the best bulb type to use on non-RS headlamps that will emulate the Bluish White color of the HID RS headlamps?
2020 GMC Sierra AT4 6.2L
WTB - 2010 Camaro 1SS or 2SS, Aqua Blue Metallic, A6
BluePhoenix is offline   Reply With Quote
Old 09-09-2013, 10:58 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
I guess it's all in an opinion but IMO there aren't any halogen bulbs that will come even remotely close to an HID projector.
IMO, either step up and do a HID projector retrofit or don't bother changing out the bulb.
Do a search in the cosmetic section for "retrofit" and you'll find plenty of info.
Build Journal
Old 09-10-2013, 12:07 AM   #3
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
I agree with the above statement, but the closest you'll get is Silverstar zXe's
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 09-10-2013, 08:34 AM   #4
BluePhoenix
Yeah, I plan to do an RS HID headlamp conversion in the spring, I just wanted to see if there was an good upgrade bulbs like Silverstars that would look nicer for the meantime.
