#Camaro6
BeckyD @ James Martin Chevy
Old 04-04-2023, 06:06 PM   #1
SS_AL
SS_AL's Avatar
Drives: 2017 Camaro RS l4 turbo
Everyone Lowers their car, but how many have lifted it?
I purchased rear wheel spacers for my 2017 RS 1LT, the only problem is that the rear tire rubs the outer fender slightly when hitting big dips on the road, Anyway.... How many of you have slightly lifted the rear suspension, and how did you do it???
SS_AL is offline   Reply With Quote
Old 04-04-2023, 06:13 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
uhhh nobody has hopefully lol
but if you wanted to buy some coilovers then you can adjust the height
kropscamaro16 is offline   Reply With Quote
Old 04-04-2023, 06:24 PM   #3
SS_AL
SS_AL's Avatar
I only need about a half inch to an inch more clearance, and hate to put a new set of coil-overs on, but may half too in the end...
Old 04-04-2023, 06:31 PM   #4
kropscamaro16
you can always throw some airbags or footballs in the back
Old 04-04-2023, 06:34 PM   #5
SS_AL
SS_AL's Avatar
Yeah, it's a cheap solution, but makes for one rough ride...
Old 04-04-2023, 11:27 PM   #6
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Drives: 2021/18 (de-fresh) 3LT RS
There's the Bilstein B6 "lift"
https://www.camaro6.com/forums/showp...02&postcount=2
The Maverick is offline   Reply With Quote
Old 04-05-2023, 04:17 AM   #7
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Why, Why and Why? Buy a 4WD.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 04-05-2023, 07:28 AM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
What size tires did you put on it that you got it to rub? Is the spacer making it rub?
WhiteMale is offline   Reply With Quote
Old 04-05-2023, 09:18 AM   #9
ThePeoplesCamaro
Patriot
ThePeoplesCamaro's Avatar
Drives: 2019 Camaro 1SS 1LE
I didn’t lift but I did only lower the front 1.5 so it has that ass up stance and some less trained eyes think I raised the back. Especially when it’s sitting on meatier 315s in the back.
ThePeoplesCamaro is offline   Reply With Quote
Old 04-05-2023, 09:37 AM   #10
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
#inb4Franputs6"liftwith31"mudders
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
FlukeSS is offline   Reply With Quote
Old 04-05-2023, 09:44 AM   #11
mRahmani
Drives: ‘23 SS 1LE
Probably better to roll the fender than raise the car, especially since the front is already dropped. However another option would be to look into adding a space to the bump stop. It will ride rougher over large bumps though.
2023 2SS 1LE “Red Hot”
Built 7/14/22
Delivered 8/27/22!
mRahmani is offline   Reply With Quote
Old 04-05-2023, 09:47 AM   #12
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
can you post a picture of your wheel fitment? it would be very unusual to add ride height.
Briland_1LE is offline   Reply With Quote
Old 04-05-2023, 10:47 AM   #13
FarmerFran
FarmerFran's Avatar
Drives: 2023 ZL1 Vert M6 "Sharky"
Like this?
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top.
FarmerFran is offline   Reply With Quote
Old 04-05-2023, 11:51 AM   #14
SS_AL
SS_AL's Avatar
So here's the problem, the Bilstein idea might be the solution, or just coil overs
lifting rear suspension, rear suspension, suspension
