08-28-2017, 10:22 AM | #1 |
Drives: 2015 2ss/rs Commemorative edition Join Date: Oct 2011
Next mod option
So I have reached the time for the next mod for my 2015 2SS L99.
so far I have bolted up a full NPP, vararam CAI and power wedge, custom tune, lowering springs, sway bars. I want just a bit more power now as my buddy just went with a stock 6th gen. I know long tube headers are an option but I don't really want to be super loud and obnoxious. I also don't want to stink like gas. i believe LTH can net me about 30hp I also hear high flow cats are an option too and can net me around 20 hp Long term goals are not to build a race car as this is my daily and I plan on keeping it for a long time but I want this SS to be tastefully modified and fun on the back roads. Any advice?
2015 2ss/rs Commemorative Edition - DynoSteve Tune, NPP, Hotchkis sport springs 19110, Zl1/1LE rear swaybar, VR-DRX CAI, VaraRam VRX-93, Z28 spoiler
08-28-2017, 10:52 AM | #2 |
i'm starting out with my mods, your the first I've seen with the vararam CAI and wedge. Since you already added a tune, think you can give me insight on weather the wedge is worth the money on top of the vararam CAI.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
08-28-2017, 11:26 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
LT's w/hi flo cats are not loud with a factory exhaust.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-28-2017, 11:40 AM | #4 |
Long tubes are a good option. I cant speak to weather they smell with high flow cats because im catless. On my subaru i had a high flow on it tho, it would smell when you first started it up. As the car warmed up the smell would go away. I guess the cat just needed to heat up. I have NPP exhaust on mine and with the long tube headers its not too bad loud wise, i have a mild to wild switch so i just turn it on and off when i want.
08-28-2017, 01:25 PM | #5 |
I wanna say I was one of the first to have the new CAI on camaro5 but thats besides the point. The Vararam vr-drx is a great CAI... I love the power and how it woke my car up before I ever had a tune.
I'm not sure how the wedge really effects the car but I did read with just testing the wedge it did make about 8-10 hp for real. I would say that every little bit is worth it in the bolt on game.
08-28-2017, 01:41 PM | #6 |
Started#gottalovethatblue
Go long tube headers with high flow cats. You won't be disappointed. If you're concerned about it being too loud, get a mild to wild switch so you can control when to open and close the NPP muffler flaps.
08-28-2017, 03:33 PM | #7 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
put in gears and a better(looser) converter...
08-28-2017, 05:49 PM | #8 |
Drives: 2011 Black 2SS Non RS L99 Auto Join Date: Jul 2016
E-85 conversion and a tune
08-28-2017, 05:56 PM | #9 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
LT headers through the stock exhaust are not at all annoying. It'll get loud when you're on it, but on the highway they're just as quiet as stock.
Long-tube headers, HF cats and a tune is my recommendation.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
08-28-2017, 09:35 PM | #10 |
Do long tube headers stink like gasoline??? I hear without cats its makes the car smell. I hope that's just a wife's tail as I wanted LT's
08-29-2017, 02:19 AM | #11 |
USA-1
It does, but I just put my windows up a bit more and it isn't too bad. I have just longtubes as far as exhaust is concerned and it definitely opens up on acceleration, but isn't really loud otherwise.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
08-29-2017, 03:53 AM | #12 |
that guy <--------
Drives: 2012 camaro V6 LS M6 Join Date: Mar 2017
Now I am probably way different because of what I have to work with vs your car.
1st I wanted power then full suspension. Turbos, list goes on. Now the nor I drive the v6 the more its present its a wicked long-distance cruiser car. More then anything I want reliability. Just simple supporting mods/ (reliability) Headers sounds like a good start with high flow cats. Have you thought about some chassis bracing. There is some sick kits out there for a decent price |
08-29-2017, 10:07 PM | #13 |
Drives: 2011 2ss/rs, 1990 iroc-z Join Date: Jul 2011
Long tube headers and hi flo cats are a very nice upgrade and with the stock exhaust should be a nice sound without being annoying. An inexpensive upgrade is to switch to 3.91 gears this will give you a nice kick in the pants without killing gas mileage. You will need a trans tune to rectify speedo and shift points but if you get it installed via dealer they will tune trans as part of install. Check with service department before to make sure of course.
2011 2SS/RS 6.4 sleeved ls7, ported CTSV supercharger; zl1 hat,fuel pump with Kenny Bell boosta pump,102 throttle body,6l90e g-force driveshaft,zl1 rearend and axels, ID 850s, dual pass heat exchanger; Auto Tech electric water pump;160 degree themostat; ls7 pushrods,rockers; Metco polished pulley kit, 2.4ud; ls3 assessory bracket kit;2 Hayes trans coolers; CAI intake; Texas Speed 1 7/8 headers; 3" Magnaflow exhaust; Alkycontrol meth kit; p;Elite catch can; BMR 1" lowering springs,
ZL1 10" front 11" rear rims, trans and engine tune by wally a. |
09-06-2017, 10:55 AM | #14 |
Do a cam swap.
