10-19-2017, 11:41 PM | #1 |
Drives: 2010 Join Date: Nov 2016
Do I need an alignment IMMEDIATELY after installing drop springs?
So my lowering springs come in tomorrow. Was planning to have them installed and then aligned. Until just recently someone told me to have them installed and then drive around for a few days to let the springs settle first, and then get the alignment. What do you guys think? Is this what any of you guys did? Is it bad to drive around without an alignment for a couple of days? How serious is an alignment?
10-19-2017, 11:49 PM | #2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
If you're buying a decent quality spring, the settling will be minimal if anything.
I put BMR springs in my car, and they didn't settle any noticeable amount. Timing your bushings is more important than letting your springs "settle."
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
10-20-2017, 12:28 AM | #3 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Any time you adjust your suspension on a vehicle it is a good idea to have your alignment checked; raising or lowing your car can effect the chamber and result in uneven tire wear.
10-20-2017, 06:53 AM | #4 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
+1
10-20-2017, 07:29 AM | #5 |
Drives: 2015 2ss/rs Commemorative edition Join Date: Oct 2011
I ended up driving around for about 3 weeks on my new hotchkiss drop springs before and alignment. It was not the ideal situation but I wasn't driving all the that far.
Basically without an alignment you will have increase tire ware and the car might not drive straight. Do it sooner then later... Its a must. http://www.camaro5.com/forums/showthread.php?t=500118
2015 2ss/rs Commemorative Edition - DynoSteve Tune, NPP, Hotchkis sport springs 19110, Zl1/1LE rear swaybar, VR-DRX CAI, VaraRam VRX-93, Z28 spoiler
10-20-2017, 07:58 AM | #6 |
Drives: 69 SS Camaro 2019 Corvette GS Vert. Join Date: Jan 2017
I recommend a few short drives with some cornering under power to load and unload the springs and then have the alignment done. You won't effect tire wear unless you continue to drive it without an alignment. I have the alignment done on my 2013 Corvette and the 2015 Camaro about twice a year because of the harsh road conditions out there. They are both knocked out of spec every time.
There is a fine line between hobby and obsession and I think I crossed it!!
10-20-2017, 08:10 AM | #7 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
YES! Get your car aligned after drop springs. If you did it right, you also timed your stock bushings. After you tighten everything up, your car will be very 'squirly' on take offs if you dot not align.
10-20-2017, 09:41 AM | #8 |
Drives: Race Car Join Date: Sep 2009
When you put a lowering spring in, it automatically changes your camber, so yes an alignment is is order.
Anytime you change a Suspension component, you will change things slightly ( or greatly). Also check into the section "Timing Bushings" as well |
10-20-2017, 10:14 AM | #9 |
Not trying to Jack the thread, but I've seen lots of talk about timing the bushings recently. I just had my car aligned, however I didn't have them "time" the bushings. How crucial is this procedure?
Sent from my Pixel using Tapatalk
12.3 @113MPH - Full Bolt-Ons w/ Nitto 555r on 18" wheel
10-20-2017, 10:19 AM | #10 |
Instagram: Sangstah
I would definitely get alignment! After I got my BMR 1.4 springs put in, the car was definitely more tail happy when getting on it. The alignment and timing of bushings made a huge difference.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
10-20-2017, 01:05 PM | #11 | |
http://www.camaro5.com/forums/showthread.php?t=151826 |
