#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Road Course/Track and Autocross
Old 03-15-2021, 08:55 PM   #1
Beescuz
Beescuz's Avatar
Drives: 2021 ZL1 1LE
Fender wells rubbing
On my 17ZL1 Last year had the rear tire rub a hole thru the fender well at Daytona. This week at NJMP the front tire is now rubbing the fender well. It puts a hole right thru the carpet fender well. Stock rims & tire size on the car. Notice when the tire gets above 38psi is when it happens. Running Goodyear Supercar 3. Anyone else had this issue or might now what is causing it/
Beescuz is offline   Reply With Quote
Old 03-15-2021, 11:55 PM   #2
rotis
rotis's Avatar
Drives: 2019 ZL1 1LE
Check the bushings in the front tension rods? GM calls them “ride links”. I think they are fluid filled bushings on the FE4 suspension. IIRC the FEA links are solid rubber and a bit stiffer.
rotis is offline   Reply With Quote
Old 03-16-2021, 07:00 AM   #3
Beescuz
Beescuz's Avatar
Thanks for the input I will check that out.
Old 03-16-2021, 07:22 AM   #4
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
38 psi is also a bit on the high side. I'd recommend bleeding more air off and targeting closer to 35 psi when hot.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 03-16-2021, 10:34 AM   #5
oneplustwo
Drives: 2018 Torch Red SS 1LE with Whipple
I have seen this on my 2018 SS 1LE as well in the rear. I haven't worn all the way through yet, but I suspect it's happening at high load sections of the track, perhaps at the bottom of a dip. Sonoma end of turn 6 comes to mind. Also, maybe bits of Laguna like the bottom of the corkscrew although that seems more gradual.
2018 Torch Red SS 1LE, Whipple supercharger, custom tune, Rotofab CAI, ZL1 duckbill spoiler
oneplustwo is offline   Reply With Quote
Old 05-02-2021, 10:58 PM   #6
evanescent03
evanescent03's Avatar
Drives: '19 SS 1LE/'19 Rubicon/'20 AT4
Known issue .. i still need to get mine addressed, see the links below for more info
https://gm-techlink.com/?p=13197
https://www.camaro6.com/forums/showthread.php?t=449791
https://www.camaro6.com/forums/showthread.php?t=579300
evanescent03 is offline   Reply With Quote
Old 05-03-2021, 01:13 PM   #7
Beescuz
Beescuz's Avatar
Originally Posted by evanescent03 View Post
Thanks Great info!
