SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 03-05-2018, 07:55 PM   #1
Quicksilver2SS
Drives: 2SS 3 pedals
gear ratio or reflashed chip cause smog trouble in Ca?
When purchasing a used Camaro and having it smog tested in Ca, what if a gear ratio change was done and or a computer re flash to correct the speedometer was done, would this create a problem at the smog station?
I see that the GM 3.91 gears are CARB approved, but what about aftermarket 3.91 gears without the CARB sticker on a car that has been recalibrated for the ratio change?
Thanks!
Quicksilver2SS is offline   Reply With Quote
Old 03-06-2018, 07:30 PM   #2
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
No issues. The vehicle no longer is ran on the rollers. As long as you aren't throwing a CEL you are all good. Gears play no role to my understanding. Best of luck!
PerformanceHeartbeat Supercharger -BTR Stage 3 PD Cam -BTR Supporting Mods -CHE Rocker Arms -Roto-Fab Cold Air -VMaxx TB -Elite E2 Catch Can -NGK Trix7's -Squash Fuel System -FIC 1000 Injectors - JDP Clutch Res Relocation -Kooks LT's/Cat-less -Corsa 3" ZL1 Black Tip Exhaust-
Suspension1.25'' Front & 1" Rear Drop- BMR (Sway's, Toe Links, Trailing Arms, Front End Links, Upper Control Arm Bushings, Outer Trailing Arm Bushings)-FMT Solid Subframe Bushings
Brake's/WheelsPowder-coated Calipers-Goodridge Lines-Slotted and Dimpled Rotors-Hawk HPS Pads-OEM ZL1 10 Spoke Wheels (285 Front/315 Rear)
Nighthawk89 is offline   Reply With Quote
Old 03-07-2018, 08:27 AM   #3
Quicksilver2SS
Ah not bad at all, thanks!
